Pitman Arm "Clocking"
Louisville, KY
OK, I posted a thread prior involving this and it led to PinHead stating that the Pitman Arm and the Gear shaft on my mini PS box has mate marks so, the positioning is very easy. Well, here is the issue:
Pin, you were right in the fact that the mini PA and gear has a mark, BUT the OE FJ 40 Pitman Arm does not. I looked and looked taking all of the gunk off the arm. It just is not there. Unless I am not looking in the right place, I do not think it has it and I have to, if I recall, use the OE 40 arm for the mini PS box.
So, back to the original question: how do I clock? Do I wait until all tie rods are hooked up, wheels straight, arm in the general vicinity, and fine tune the drag link?
Thanks
That is what I would do, but I would not tourque the arm up until I am sure that it is centered....you may run out of adjustment in the relay rod and drag link if you have it too far off...
Good luck!
-Steve
Do you think I would be close if I took ALL of the steering linkage bck to OE specs i.e. what the FSM call typical tie rod to tie rod end length, center the wheels and use that as my "center" for the box? I would think that would be pretty dang close....ideally that is.
Hmmm, my recollection is that my FJ arm had a line too, but I may be wrong. No big deal. Just center the wheels and the box (count the number of turns and divide by 2). Then slip the arm on. If you are off by a tooth, you will find that your turning is limited in one direction. (Helps to have the front wheels off the ground to check this) I fooled with clocking seeing if I could reposition the arm to allow the box to be moved forward and I found that the only way to do it w/o screwing up the turning was to shorten the drag link by the same amount.
OK, just so I understand. I am counting the revolutions of the Pitman arm gear shaft from full lock to full lock. I can do this by turning the input shaft clockwise or counter clock until it locks, mark the position of the PA gear shaft in reference to a mark (same position as the PA gear shaft mark but on the gear box), rotate the opposite way, count the revolutions in reference to the gear box mark/PA shaft mark until I am at the other lock, divide by two, go back that amount and that should be the center. I can then mark another mark on the PA arm/gear box and that will be the center like the mini PA arm and box had from the factory.
That position should, ideally, be very very close to the right position when I reassemble according to the OE TR length specs. But if not, I need to adjust the drag accordingly.
Am I correct in my thinking?
That's roughly what I did on my Fj55, got pretty close. The drag link isn't adjustable on Fj55, so I need to get around to centering my steering wheel next, when I get around to it...
Nial
Just slap that biatch in there and quit worrying. You will notice if it is off a tooth if you check your wheel turn radius in both directions. Just don't tighten the nut until you are sure or you might have to wrestle with the Pitman arm puller again.
