Piston size??
Kansastitty
I'm in the process of rebuilding a 2F 1/77mfr and the pistons are domed with a flat rim and the number "3" stamped in the rim. Does this necessarily mean that they are .030 oversized? It is supposed to have about 87K on it and it looks like it. I just heard somewhere that pistons had a # stamped in the top.
I'd include a pic, but the wife took it on a trip. I think she's coming back on Saturday, heh.
Ed
Well, it does have a number stamped on the top of the piston. #3.
Good question I don't know. I just tore apart a 2F which was supposedly rebuilt a few years ago, and behold what did I see, a #3 on the piston edge. I can only assume this is a 30 over piston. I will do some more asking and see what I can find out.
Ed,
If the piston is .030" OS, it will have .030 stamped on top. If it is .75mm OS, it will have .75 stamped on top. The single digit number stamped on a stock piston is the size class. The factory measures pistons and bore size to the thousandth of a MM and fits them together for best tolerance. You will also see size class numbers for the rod bearings stamped on the oil pan rail. Size class for mains is stamped on the main web.
Ed
Thanks, Jim. Exactly the kind of info I was looking for. So in the absence of any other markings on the pistons, these may be the originals?
Thanks,
Ed
Thanks,
Ed
If they are OE then they will have the TEQ mark on them. I just dissassembled a 2F last saturday and they had the TEQ. I'll take some pics of one of them.
Arron, where are they marked?
Thanks,
Ed
Well I checked with a knowlegable source and basically said the same thing as FJ40Jim.
The stamped number basically indicates a matched piston set.
Pistons that are oversized "should" have the OS designator stamped on the head. Seems this is not always the case, I have seen a few OS pistons with no markings what so ever.
