- Joined
- Jan 6, 2003
- Threads
- 64
- Messages
- 1,216
How much freeplay should there be in the front (or rear) driveshaft at the pinion flange? I'm in the process of doing some work on the FJ, and I've got the front driveshaft out. At the pinion shaft, I have a little bit of rotational movement when I turn it before I see movement of the axles. How much is too much? There's no side to side movement at all, just rotational. My gut feeling tells me it should be tighter, but I've read some opinions saying some amount of play is normal.
It drives fine with no noise, no leaks, no problems, but since i've got the axle out anyway, I'd rather do any work now rather than later. Thanks
Edit: Actually, I just realized it's more the whole axle backlash than pinion backlash. If i were to lock the axles and jack up one tire, how much should one tire rotate before I feel it stop? There's some play in there somewhere, I'm just wondering how much is normal.
