Pinion advice please
Blenheim, New Zealand
Before I start - I have done a search & learned a lot about the mysteries buried deep in the diff housing, but not exactly the details to understand my problem.
About 2 months ago, I developed severe vibration in the driveline, which I traced back to the pinion nut which had come loose. I torqued it back up & hoped no damage had been done. Wishful thinking...
Not surprisingly, the pinion oil seal is shagged. On it's own a relatively simple fix, but the pinion now has a little bit of play (side to side). Not enough to cause any vibration, but enough that I'd like to eliminate it. Is it possible that the shims got damaged while it was loose, & the bearing pre-load has been changed? If so, is it as simple as adding another shim? Or is that heading for more trouble?
A little history - the diff was originally in the front (with free-wheeling hubs), & as far as I'm aware, it probably had relatively little use through the life of the truck. I moved it to the rear when I put in a lockright (and put the LSD in the front). At that time (6 months ago) the pinion had no play at all, and from my limited knowledge, there were no signs of wear on any of the internals. So I'd be surprised if the bearings needed replacing, unless they were damaged during the brief time the pinion nut was loose. I got onto it pretty quick after the vibration started, but by then it was quite loose - it took about 2 or 3 full turns to tighten it up.
Thanks in advance for the good advice I have learned will always come my way from the mud team.
Pull the differential and inspect it. You probably are going to need a new pinion bearing and or new crush sleeve if the diff was not setup with a solid spacer. Your other option is just to run it until something happens, probably not what you want to do.
I went through this ordeal recently too. I had a spun shim (which is very common). If you are mechanically inclined and have time to kill, it is not that difficult. But it can take a lot of trial and error (assemble and disassemble to get it right). If you have never set up ring and pinion stuff, you probably do not want to go there. I also had a damaged flange, it had a lot of play in the splines. It had to be replaced. Just fixing the seal will not work, if you tighten the nut down to specs your pinion probably wont even turn.
As most of us have seen, our pal zippy is one of the foremost authorities. Third members are common and cheap and are relatively simple and quick to swap.
Well, I pulled it all out - swapped the shim for a new one - 0.25mm (it looked exactly the same as the one that came out) - torqued it all up & there is now no play at all in the pinion. The nut has turned about 1/8 turn past the previous mark. Hopefully that will be problem solved, but if not, I know where I can get another diff head for a reasonable price. I might get it anyway - I can probably get a whole front axle for a good price which would give me spare CV's, axles, & hubs as well.
A couple of handy tips I found:
To break the nut loose - get the breaker bar on the nut & wedged against the spring, then drive the truck forward in low range. No way I could shift it by hand, even with a 4 foot pipe over the bar.
An old clutch release bearing is a perfect fit over the pinion seal to tap it into place.
Thanks for all the suggestions.
While that is not really setting the preload, you may get lucky if the preload washer didn't get ground down from the shims spinning. If you torqued it down and it turns as easily as the other differential it may be OK. If it is too hot to hold your hand on after driving 20 Km at 100 KPH, then the preload is probably too tight and it won't last long. Turning the nut 1/8 turn past its original location is consistent with it being tighter.
Changed the diff oil & took it for a run - no sign of overheating around the pinion. Just a nice warm housing as you'd expect with the pinion area the same temp as everywhere else. No diff noises either. It looks like I may be lucky - but I guess time will tell...
