Ok, I am at the end of chasing this. When in 4th and motoring along the highway around 60mph everything is Ok. However, when I start to apply just a bit more throttle (say for uphill or something like that) I get the dreaded pinging. If I let off the throttle or give it a bunch of throttle it goes away but it will just ping away if I stay at that throttle point. I have noticed that in the cool morning it isn't anywhere near as bad as when it is 90 plus. Any suggestions are welcome. Here are the facts>
Stock 2F with MSD ignition.
Good plugs gapped out to .60.
New rotor and cover.
New wires.
Carb is adjusted pretty well.
Idle timing set to 5-7 degrees.
Vacuum port pulls between 0-20.
Everything connected, (wife running the RPM's high, while I look at the timing) the total advance at a high RPM is around 25 degrees.
Thanks in advance,
Travis
New wires.
Thanks in advance,
Travis
. If I retard the timing too far what are the repercussions? Also it may be my imagination but it sure did seem like the cruiser was using gas a faster rate?!?
