Pilot Bearing Fiasco!
What a frustrating day.
I started early this morning to assemble my SBC to the NV4500 in anticipation of setting them in the frame. After cleaning everything up I started installing the clutch disk and pressure plate. Broke off a bolt in the flywheel had to remove the works and start again. (bolt came out easy).
Next came the AA bellhousing. All went well here
Then I lined up the transmission and tried to bolt it up. It would not go together. I figured I did not line up the clutch disk, so unbolted everything again and realigned the works.
2nd try went a bit better but the transmission lacked about 3/4" from being tight. I decided to try and bring them together with some long bolts. Bad decision!! Stripped the threads out of the bellhousing (aluminum) and only closed the gap to 1/2 ".
Now I take everything apart again. Next I try to fit the transmission to the engin with the bell housing removed so I could see what is going on. Still end up about 1/2" shy of make-up. Next I pull the pilot bearing out andsee what happens. IT FITS!
This was a new crate engine (Ram Jet) with a shouldered pilot bearing. (3/8 " shoulder)
Now I need a new pilot bearing. What is best a bronze or roller. I hope they make them without a shoulder!
Oh, need to heli_coil the bellhousing too!
Nocents
I'm working this through with my swap as well. Since the roller is only $8 or $10 more, I'm going roller. Why not?
Half an inch is a long way for a pilot bearing problem. Are you sure it is the correct one? GM has been making the same bronze bushing for all pilot bearings since 1936 and it hasn't changed as far as I know. I have never seen one with a "shoulder", but I haven't looked at any new ones for 10 years.
definetly run the bushing.
ask yourself why?!
when's the last time you hear of a bushing failing?! it will outlast just about anything else in the vehicle, given proper lubrication and installation.
pilot bushings are made of a material called oillite. if you look at it under a microscope, you'll see that it looks like a sponge. they're designed to hold as much oil as possible and then slowly "give off" that oil to keep the mating surfaces lubricated.
henec, the proper way to lube a pilot bushing is to soak it in engine oil for a day or 2. more won't hurt either.
DO NOT USE GREASE, as this will clog the pores in the bushing and cause premature failure!!!!!!!!!
bearings can and will fail. just take a look at the thread in this forum will the busted bell housing!
afwiw: when installing a new clutch, always make sure the pilot fits over the tip of the input abd the clutch splines onto the input as well!
also, pressure plate bolts only get torqued to 18-21 lbs!!!!!
i would also try the bellhousing on the block without the trans and clutch, just to check everything.
I went to NAPA and for $2.50 I got a non-shoulder pilot bushing. Too late tonight to try things out,but I am confident this will solve the problem!!
Thanks for the feedback. I thought a needle bbearing was not too good of an idea. I'll stick with the bushing. I already tested the fit on the input shaft. Slides right on. I'll lube it up with engine oil tonight.
Nocents
put it in a small container and let it soak in oil overnight.
also, when using pilot bushings, check them with a magnet. if it is magnetic, it's partially ferrous and will wear down your input shaft over time, but not much. true bronze (non magnetic) pilot bushings are the best!
Got it all bolted up tonight......Damm pilot bushing was the problem.
Oh well now on to getting the motor in the frame.
Nocents
