Well, It has begun... I have said I was gana do it, It actually started yesterday... I plan on cutting the back half of the truck off, taking out 15" and welding it back together. It looks like I will either "BOB" the gas tank or make a whole new one from scratch. The depature angle will almost double plus its cool. I didn't have any good before pics so I had to work with what I have. I'm hoping it will like something like the second picture when done... I was very opposed to BOB's until I saw how well done MACE's 60 was. I hate when people chop wagons up and make them into P/U's - Just buy an effing P/U if thats what you want and don't bastardize a 55. Anyway, any suggestions will be helpful...
bobbed! I installed a 2 1/2" body lift & am running a mid 90's S10 gas tank which fits perfectly. I also cut the body channel above the stock tank area & reinforced it. You can rotate the S10 tank so it's inlet is on the driver side. I run mine on the pass. side. No advice here on adjoining the rear sheetmetal once it's been cut. I tried it & gave up
Then, I whacked off all that low hanging weight on the rear & replaced w/ tube
Hope you have more patience than me on sheetmetal work
Good luck it's great to see more
out there instead of reassembling a stocker
You like men...
