Pictures of FJ60 with 44's on it?
My freaking 35 MTR rub like hell!
My 37s rub slightly, but only on the front of the front fender. A shackle reverse would make them rub on the rear of the front fender so I will leave it be. The 37s tuck in the rear real close to the front and rear of the fender, but don't rub.
What width tire and what BS wheels ya running? My 35's rub big time in the front!! (rear are fine) You running longer bump stops?
heres a pic:
Waggoner5 said:
Yes 4" bumpstop extensions, 37s on 15x10s with 3.5 BS.
Nice rig!
Where does one get bumpstop extension? Or are they a custom thing?
If you look close, you'll see that tippyR's 53's are bolted to unimog axles (which have quite a lot of gear reduction), and is powered by a turbo Diesel engine (I forget if it's a 13B-T or a 12H-T).
I agree, Quite the truck!!!
Hi Steve...Peters truck is powered by a 3B, with turbo, and there are a couple of t-cases in there to assist turning things. He is currently bulding a 1HZ for it.
gb
Waggoner, do you have flat springs or an arched spring with your SO? I have new OEM springs and longer shackles with my SO and I don't see how I could run 37's. I also have the extended bump stops (Man-A-Fre sells them). Just curious.
