Are you all ready for something a little different?
I wanted an off-road capable truck with a low range 4x4, that is easy to work on and all terrain tires. I wanted to be able to haul a large trailer and/or boat.
I also wanted it to drive like a car & to be able to haul up to 8 people in comfort. And to look as stock as possible.
And I wanted a 7.1 surround sound system with a DSP & back up camera.
Here is the solution:
Lexus LX 470 (LandCruiser)
DC Power Alternator 260a - voltage while running both ACs full blast and stereo at full tilt it stays at 14v+
Dynamat Extreme everywhere
Three Batteries (1 under the hood & 2 in the rear)
KenWood Double Din DVD (that can play Flac recordings)
JBL MS-8 Surround 7.1 Sound DSP
Three Arc Audio 1200.6 xDI amps. They are 6 Channel amps are capable 1,200 watts each or 3,600 watts total. (150 watts a Channel or 600 watts bridged.)
Focal K2 ES 100K 4" - 2 way components as the center channel.
Focal K2 165 KRX3 6.75" - 3 way components in the front doors.
Focal K2 ES 165K 6.75" - 2 Way in components the rear doors.
Focal K2 ES 100K 4" - 2 way components behind the 3rd row.
Two AudioFrog GB10D2 - 10" Subs - Each Sub in a divided box with 1.75' per side. Rear firing & ports on each side near the bottom.
