PHH success....
North GA
Worked with my mechanic yesterday and replaced my leaking PHH as well as the throttle body gasket. The PHH hose had what looked like little pin holes all over it with coolant seeping out. And the gasket has a black coating on it when new that creates a tight seal; the old gasket black coating was flaking off when I removed it. Pulling apart the TB over the weekend compromised the gasket and that's what created my rough idle. Now she's back to a normal smooth idle.
I still have the check engine light even after I cleared the code; with 380K miles I'm sure the EGR valve is clogged up. I do have a question about a particular hose; looks broken and when I put my finger on the end of it there was suction. I stuck a BB in it temporarily just as a temp fix. What hose is this? Just another vacuum hose?
That fitting is for the fuel pressure regulator it goes to a small metal tube up towards the f.p.regulator uh muy importante to fix it new part is about 30 bucks iirc.it is a breather that supplies steady vacuum.mine was broke at the nipple I just j.b.welded a new nipple on.
The '97 only has ONE hose feeding out from that vacuum adapter (or whatever that device is). The '94 has 2 hoses feeding out. Seems like someone 'recycled' a part from a '94 into your '97.
cheers,
george.
That PHH looks like it was about as close to a meltdown as you can get. Points out out that simply inspecting them is worth the trouble, as it was obviously decrepit.
One hose and only a spot for one hose, this on a '97 (that I've owned from new).
cheers,
george.
Good call on the vacuum adapter hose George; for the life of me I couldn't see where another hose coming from the nipple would run to. Makes sense.....guess the bb I stuck in there won't hurt anything. Before that there was suction coming from it.
We used 5/8 Gates heater hose for the PHH....original clamp on one end and a screw down on the other.
Maybe something with a head on it might be better. I imagine it's probably not a totally open circuit, but I'd hate to see that little ball get sucked in. Replacement for the appropriate model probably isn't $$
