My suggestions having done two of these...First, do a PHH search here and read as many of the threads as you can to pickup some tips/tricks that could prove very useful.
Some specifics suggestions from me. No, you don't need to drain your coolant (about 1 gal or so will drain out though) if you have recently done a good flush and have new stuff in there...If you haven't done a recent flush now is a good time to do so. On my LX I did a full flush and replaced all of the other cooling hoses including the FHHs at the same time. On my 80 I was pressed for time and just replaced the PHH without draining all of the coolant.
Take the tire off, the rubber/plastic "skirt", and personally I would remove the starter (and rebuild it if it hasn't been done in awhile). With the starter out (even though getting it out can be a PITA) you have a ton more room. With the starter out you also have easier access to the block drain. You can rebuild the starter while the coolant is draining (leave the radiator cap partially on or be prepared for a huge mess
. I also unbolt, and push out of the way, the AT dip stick/fill tube.
Be careful of the knock sensor just forward of the PHH. I read posts before doing my PHHs of people busting the knock sensor off and ending up having something else to fin. Knowing it was there and being careful I was able to avoid it
Oh, and don't forget to put the clamps on the hose or pushed up on the hard tube BEFORE you get the new PHH in place...DAMHIK but it is easier than trying to get them on after the fact...
