Phh Installed!!
KIRKSVILLE, MO
I just finished installing the PHH http://www.1fzfephh.com/, on my LX450, after reading several threads here and suggesting replacement after 100k. Since we have 173K and upon inspection the ORIGINAL OEM PHH, I knew we were on borrowed time. OEM PHH.webp
It appeared that most accomplished this PHH replacement in a few hours. I anticipated it would take me the same amount of time, I was wrong and now call the PHH a FHH :mad:!
There were suggestions to remove the valve cover to access the lower (2nd) bolt on the tube connecting the PHH to the engine block.
Or to reach up from the bottom (or wheel well) to access the 2nd bolt for loosening - however my arems are too short or don't have the 3rd or 4th joint apparently necessary to get a wrench up there!
In the smallish town I live in I didn't have access (couldn't immediately buy) to the ratcheting-box-end-flex wrenches that were recommended to help with this repair, so I took another approach.
From the engine bay, I removed the tubing and heater valve assembly attached to the firewall and this let me get to the 2nd bolt with my 12mm Gearwrench.:)
Attached to this heater valve assembly were more OEM heater hose with the "sardine can" clamps (removed with a dremel tool). This was a good time to replace these hoses too.
I ended up removing the 2nd bolt (not recommended) since I couldn't get the new silicone PHH on the enging block nipple and the PHH tube to line up. To retain the 2nd bolt and not have to thread it in the rear of the block I slotted the bracket on the tube.:idea:
From there everything went together fine.
Another suggestion for lubing the hoses, since I did several of them in this repair, is to ues KY lube - water soluble and won't hurt the tubes or cooling system either.:eek:
I gotta do the PHH this weekend.. Or should I say FHH
Have your tools & parts laid out and take things slowly!
I used a pry bar to remove the fender skirts & saved the plastic retainers.FLAP REMOVAL TOOL.webp
Also, here is the picture of my slotted bracket. Didn't know how to attach it to the first post.SLOTTING BRACKET.webp
Good luck, get the tools and I think you'll have a better time! You may still cuss though!:D
I'm gonna get the ratcheting flex head wrenches before I attempt the job...
I did mine a couple weeks ago. Had my wife help take the clamps off the old hose. She could get both hands in there lol..Nothing like a greasy blonde haired beauty. Kind of turned me on.
Check the other posts for more suggestions & directions for this PHH repalcement - and good luck!!!
no need what so ever to take that hard line out. You made a tough job into a hard one.
With just removing the one easily gotten top bolt you can hinge the tube on the other bolt to slide the hose over the end of the tube and then onto the nipple n the block.
There is a write up on Slee's site that out lines a step by step procedure for doing this.
I agree, things got more complicated, and other posts/instructions are a real time, energy and cussing saver!
I used instructions but ran into problems, also thought replacing the extra hoses was prudent since i was already working on the cooling system. I finally had some forethought!:)
I couldn't get the bottom bolt loosened enough for the hard line to swivel and install the new PHH.
And i think i got a little gorilla handed on the hard tube and may have bent it where it ditn't want to re-align with the block nipple. So, a removal and rebending was unavoidable - therefore the slotting of the bracket seemed a good way to recover from my mistake(s).
I just thought access from the engine compartment hadn't been addressed yet - so i thought my post may help someone else.
Did mine 2 weeks ago, took me and a friend 3 hours. We simply twisted the pipe and broke off the 2nd bolt support after the mosquitos were having us for dinner we didn't want to fool around. No leaks since, even with only the top bolt in place.
LMAO...FHH...whew!!!! I just did mine this weekend and that's just what I was thinking along with about another half a dozen expletives! :lol: I struggled for I'm not sure how long without taking the transmission dip stick out of the way until :idea:. After I did that it only took me about an hour (longer). Mine had been replaced once before and was leaking again. I found that it worked pretty well to jamb on the block side first which was pretty easy...then the hard line which was a different story all together...akward position to get leverage to push not to mantion getting the d**n thing to line up using only one arm...wish I would of thought about the KY thing...ended up using old fashioned saliva which helped. Seemed like they must have loosened the hard line on the bottom from the previous install so that must have helped a little.
If we've done the FHH...does that mean we're still newb's or do we have to do a Birf service as well?:D
i agree, it was the best $250 i ever spent!.
good point terminator!:D
is it the # of posts or the # of :banana::banana::banana: s that a job takes to get off the rookie list?
the next projects for me are new OME springs (already did this on my, Landrover Discovery, replaced with the LX450) and the axle seals, maybe after those projects & posts my newbie status will be history!:beer:
Besides the satisifaction, and scratched & bruised arms, doing the PFF myself saved be/earned me $250 for LX upgrades!
HOWEVER, i will be looking for posts regarding my up-coming projects for tips, ideas, tool suggestions, etc.
I am really thankful this site exists!!! I need to make a donation to keep it open since the information has already saved me $$.
Man, I just ordered some swivel head gear wrenches for this job. Looks like a PITN. I have really considered having a shop do it as they only want $120 for it. Quick question, I need to a coolant system flush also, should I do it before or after the PHH???
After or during re-assembly. IMHO
Doing it yourself will help pay for the wrenches and they're very handy to have. I've used mine to replace the fan belts and the FHH...er...I mean the PHH! :D
It's actually satisfying having done the replacement. Knowing whats involved in the replacement could come in handy for yourself or a fellow cruiser someday.
