PHH installation cost
Letsee...
OEM Toyota coolant $28 per gallon - two gallons = $54.
5/8" Silicone heater hose $9/foot = $2.
Fully sleeved hose clamps $2 ea. = $4.
Parts cost (done right without going continuous tension crazy ~ $60.
Labor ~2hrs assuming a good tech who knows their stuff @$85/hr = $170.
Total should be around $230.
It makes me wonder if they either don't understand the job or plan to skimp somewhere - like using generic green coolant - or both.
Letsee...
I'm sure they are assuming the green coolant but that's what I've been running in there for the past 4 years. 0.7 hours of labor @ $95/hr = $66.50 so therefore $34.11 for the coolant and tax.
(I'm providing the hose and clamps from www dot 1fzfephh dot com)
That is a good price, but my OCD side says I won't worry about whether it was done right if I just do it myself. I'm a gluton for punishment I guess, but my conscience kills me on this kind of stuff...
If I had someone else do it I would probably go in there and make sure everything was up to par anyways, so why not just do it myself which is what I did.
Something tells me that for $100 Flem isn't getting a coolant flush :meh: - My gut feeling is they'll just catch what comes out (in my case when I did the 80 is was maybe 1/4 gallon or so) when they pull the hose, put the new hose in, and top the system off and call it good. But maybe they are and that is part of the quote...
It it were me, I'd bring them the hose and clamps I want them to use (like the silicone hose kit I used) and just pay them the labor :) - Oh, and verify exactly what it is they plan to do so there are no surprises when you get the bill...
I'm having this done by a garage right now. I bought a silicone hose kit and had it mailed to them.
I told the mechanic where the hose was. I'm pretty sure he is gonna fit it ok. I'm also pretty sure it is worth $100. to get it done. I don't have a lift. If I did I would do it.
I just finished mine two weeks ago. I'd probably pay $100 for somebody else to do it looking back. It took a big chunk of time out of my weekend, cut up my arms and pinched a nerve in my neck. Hair on my right forearm is growing back nicely however. ;)
My mechanic gave me an update on the PHH replacement - his tech is still working on it and he says that it is "not classified as a heater hose" - not sure what he thinks it classifies as other than a PIA. He's willing to work with me on the labor as the thermostat replacement took less than book time. I was up front about the job, sent him links to articles on it showing that it is indeed a bugger to replace so he should have had an idea that it won't be cake walk for a mechanic over my one:banana: skills.
We'll see what he's thinking for labor. Not that they need my business but I'd hope they'll want to keep customers.
i wouldnt be surprised if your quote doubled. considering it was a fairly low quote, however, they didnt quote with toyota red, so they probably wont pull the rad & block plugs and do a proper flush. just refill with green in which case..its an accurate quote for what you're getting.
fwiw, i did mine myself. flushed the old coolant out via rad & block plug. used toyota red. and put in new starter contacts while i was in there. tstat replacement is a 5 minute job. no lift needed...and my knuckles werent that bloody after...
Thermostat and PHH $190 (2 Hr) He admitted that the PHH was a PIA!
Oil Change with my synth and Toyota filter $10
Tire rotate and balance for a bad shimmy at highway speed (one wheel 5 oz off) - this and the T-stat is where I think they made up some of their extra PHH time investment $67
Supplies and what not $20 for a total of $287
Starter is a re-manufactured Toyota 2.0kw so his thinking is that it was replaced by the PO and shouldn't need servicing for a while.
His opinion on my rusty rear heater hoses is that we should figure out a bypass since he's not seen a rear heat system stand the duration of MN climate (winter salt) for 100k yet.
Piece of mind for our our trip across MN and WI towing a trailer over the holiday - priceless...
