PHH installation cost
Twin Cities
Website
www.myspace.com
I just got a quote from a local shop on installation of the PHH of $100.61 part/labor/coolant/tax. From what I've read here on the forum it seems that it's worth my knuckle skin for that price (though I'd have them install the green stripe with the constant tension clamps for a little more).
If you've done the job yourself, would you pay this price to have a reputable shop do it?
While it was nice 'knowing how' that's a very reasonable price and I'd let them do it for that if you really aren't into the pain, agony and swearing at that damn little piece of hose. :D
I've done two and yes for $100 (including parts) I'd pay someone I trust to just do it :D - IMO you aren't learning anything valuable by doing the PHH and if the PHH is replaced with quality stuff and done right, you won't have to worry about it for another 100K+ miles.
If you haven't rebuilt your starter or it has been awhile, you might want to throw that in there as well...Tell them the PHH is MUCH easier to get to with the starter out of the way so while it is out for another $50 (including parts) they can replace the starter contacts and plunger :D
I like to wrench on my stuff but IMO the PHH just isn't an enjoyable job :steer:
It's not much fun to do yourself and it can even be frustrating. If they do a decent job I would pay $100 easily if I had the money.
I'm guessing if they are only charging you that much they have never done one.
It might not be as hard for a shop to replace. I've done 3 originals from the factory which is a pain simply because they put the spring clamps in a position you can't get to. But at a good shop, guys have a wide variety of odd angled pliers including needle nose with curves, etc. The mechanic will probably walk across the shop and borrow a set of pliers that will let him grab it right away and spin it down to within reach. If it weren't for this aspect, the PHH would simply be a hose in a tight spot. Those $%&&*( original spring clamps are always facing rearward where you just can't get a tool in there.
DougM
I picked up a set of these and it made the job easier - in fact I'd no problem getting the old hose off at all.
Getting the new one on however....
Now I've a spiffy set of hose clamps I can reach for the next time I've a clamp in a PITA place.
Craftsman Cable Operated Hose Clamp Pliers
I should also point out I aspire to reach the heady heights of a 1 :banana: wrench some day with practice and the help of ih8mud...
Not that hard. Did mine in 5 minutes. Just pull the body!:flipoff2:
what's with all these pliers? you want to keep the clamps as a souvenir? Just cut the darn things....
(says he who has not yet done this job.... :))
That's exactly what I decided to do. I have some physical issues, in addition to being over 50. I was still under 30 and didn't have those issues when I had my last Landcruiser. Age alone wouldn't stop me, but there is simply less and less I've been able to do -- and now a lot less the doctors insist that I do.
We bought the 80, I inspected it, figured out what I could do, the wife gave me a budget, and I then took it to the dealer to catch up on what turned out to be 50k of neglected PM by the PO.
The service writer said the mechanic said he could do it in an hour and half of labor. I don't think they used either a flat rate manual or the Toyota program, just eyeballed things.
One things for certain. Putting it on a lift to do the deed has got to be easier than at home in the garage. You decide whether it's worth it. I agree with those who say you're not learning anything is you've ever changed a hose before. There are lots of other hoses to practice on if you need that sort of OJT to get your merit badge.
It's all relative. Do you have more time or money?
It can be done by you for a lot less, but as others have said, if they stick to that quote, to me it would be worth the $100.00 to avoid the hassle and scrapes and bruises on your forearm. It's not a fun job. Usually you have a sense of accomplishment when you're done with a job--this one you're left with bruises and a dirty mouth.
edit: since when is scra pe a word that needs to be edited by the system?^
Also, this includes a cooling system flush and the coolant. Last time I changed my coolant, (3 days ago) the correct Toyota Red non premixed fluid cost me $43. So, they're doing it for pretty cheap considering the coolant, hose, a flush and no agonizing aggravation.
DougM
Doug,
Good point, as that was part of the deferred maintenance I was having done at the time. 2 birds, 1 stone.
Make sure they know about the rear heater (have heat setting on hot when truck is shut off for service to open the heater valve) and the block drain (14mm bolt rearward of the oil filter) so it gets properly flushed. Back flushing is best to get both heaters properly cleared. I also like the starter maintenance as part of this work, but you can do it yourself on the bench at home as well.
DougM
Thanks to everyone for the advice. I suspect they haven't done this job before but they are a reputable shop that primarily services big rigs.
My rear heater hoses are in bad shape from MN winters and I'm considering having them replaced or bypassed as part of this work.
I also have a new thermostat sitting in my garage that I'll see if they can pop in and do the starter contacts and plunger. Does anyone know how to tell from my VIN whether my starter is a cold climate one (2.0kw) or the normal 1.4kw one?
I'm running the green stuff for coolant now so I suspect that's what they'll replace it with.
Anything else I should have them do while they're in there?
Thought about it and got nervous about going a little too heavy with the dremel and cutting the block nipple.
It's a PITA place to reach and I didn't fancy swinging a dremel around in there - but as I pointed out, I'm sub a one :banana: wrench :)
My primary concern on most tasks is not screwing up too badly :whoops:
I guess it's mostly a confidence thing.
BTW e9999 : Thanks for your write up on the full coolant system flush - it was very helpful and since I had everything dry I took the opportunity to back flush the heater cores and switch to 'Yota red. I also replaced the thermostat and hoses while I was at it.
glad that write up was a bit helpful. I spent so much time doing that flush that one time that I have not done it again since... :o
PHH wise, from what I remember reading, it looks like I will bypass the metal tube altogether when I do replace the darn thing. With an extra hose around the real one for protection, I'm not seeing much drawback.
be really clear with the shop about what you want hose wise and coolant wise. They might try to cut corners if they spend more time on this than planned.
Thats a good price. My shop charged $90 to do this job but I elected to go with the "bypass" which seems to be frowned upon by most but it's been almost 7 months and about 8500 miles with no issues. I did buy a 2 ft silicone hose and the constant tension clamps from McMaster Carr so the $90 was labor and coolant. Still a deal IMO.
