Petronix installation - what am I missing?
Nairobi, Kenya
Yesterday I took apart my distributor and tried to upgrade to Petronix on my ‘67 F engine. Took out the points, removed the condenser and installed the unit. Also wired and connected a new Petronix coil.
I still need to connect the short ground wire and place the rotor back, but when I put it all together, the truck cranks but would not start. Looking at the photo, what obvious thing am I missing?
I would Re-read your install instructions that came with the kit and get refreshed on them as well , your missing the ground strap attachment point at the cap clamp down if i recall correctly ?
Need your Rotor back in too ..........
1906490
Thanks, but I said that about the rotor and ground. It’s just easier to take picture without the rotor. Nevertheless, attaching the ground and placing the rotor in will still not start the car.
i wondered when reading if that was the case or not ?
ok , next is to verify u have the B+ and Neg- on the correct screw terminals and Not reversed by mistake ,
then get a test light and verify u have Key ON B+ power going to the coil at all times with the Key ON , and also when cranking too
make sure u have a Neg- to the coil too from the Dizzy black wire
, theres a few more steps , but see i the simple ones work first
also , did u take the Distributor out of the vehical , install pertronix , then put it back in the engine by any chance ?
No, I left the distributor on, just removed the cap and “gutted” the inside. The black wire goes to the coil’s negative, the red goes to the positive. Also, there is wire from the starter to the positive ( the same I had for the previous coil in place).
ok good ,
but did u verify with a test light B+ voltage there with Key ON position after u installed the Pertronix Coil
& re-attached the wire from the starter u mentioned ?
i would triple verify that step , and subsequent Neg- to the other coil terminal on coil
ok, so verify u have power or not , that is really the next logical step and a simple one too
if u dont then u know what the problem is
if u do , then we know its Not a electrical issue and move on to mechanical reasons
good luck
I checked and there is full voltage on the + terminal of the coil when key is ON.
what about neg - / and solid ground ?
use your test light again , put clamp on the B+ terminal of coil ,KEY ON , since u know now u have it , & touch the NEG- terminal
of coil , if u get test light up , then your good ,
Ok, so here is the problem. There is no ground on the NEG terminal. There is only one wire, Coming from the distributor. Is the problem the short ground wire inside the distributor? Do I get ground from the main body of the distributor base?
The Pertronix Igniter Box has a RED wire and a Black wire coming out of it , where does each color wire go right now ?
in your photo , the Black wire comes out the dizzy with the Red wire , Then what ?
be very descriptive and accurate exactly here when u reply
or better yet Post some photos
ok,
- set your octane selector to zero
- loosen up the dizzy clamp slightly , and rotate the dizzy couter clock wize first a bit and see of it starts , with cap and rotor on ov course
- also it looks like your RH side cap clamp is missing or not attached , or that just the photo making it look like that ?
- if no luck , then try roteing it clockwize a bit at a time to see if it starts
- make sure the octain selector stays at zero while doing this
it should want to turn over .............
Sorry for the stupid question, but what is the “octane selector”?
I’m struggling to reattach the right clamp so I was holding down the distributor cap with my hand while a body cranking the engine. It did crank and turned but no start.
Never mind! I found it in the manual.
The octane selector is the KNOB on the side of the distributor. It is there because different octanes create different timing issues, and these vehicles sometimes lacked good quality gas stations in the world. So, putting it at zero is ensuring your timing is not the issue.
I did this change on my 1969 and found out that the timing with pertronix in there is different than with points. My best running position the needle cannot be seen with a timing light. Probably 11 to 13 degrees when the points were 7 or so.
Go to harbor freight and get a cheap tester to see if you get spark at the plugs at all. Quick and easy.
1906694
I have never installed pertronix and have had a DUI for sometime... no coil, igniter or resister... so, I don’t recall coil, igniter wiring.
So... potential dumb question, but for clarity for those in the know...
The only wire that runs to your coil-neg is the black wire from the pertronix?
It seems like there should be a negative, from igniter to coil-neg... but, I’m not sure anymore.
