petering, lerching
Got truck back from shop after new rad some trany fluid was lost and it ran like crap i brought it back they added a liter if trany fluid and it still is not as smooth as it was before i took it to them. how do i get it back to the way it was. it slips out or reverse if i give it lots of gas. sounds bad i know
Sure it's the right fluid ? At the right level ?
That's the only simple things I can think of that would be easy to check .
Or, just do a drain & refill so that you know :) you have the right fluid in there.
This is assuming that these symptoms were not present prior to the radiator R & R . :confused:
Perhaps someone with more detailed knowledge will chime in .
Best of Luck !
Britt
Just make sure they filled it (or not) with the ight fluid. Then we will go further with the issue.
Frankly speaking, they wouldn't loose much fluid if they disconnected the tranny cooler. Maybe half a liter (or half a quart) or even less. Maybe they really messed something, maybe the tranny was low on fluid before or maybe they overfilled it. Check the fluid level (with engine running).
I think he ment to say "right fluid". I think 94 newbie was on the right track. Do a complete tranny service -drop the pan, clean the pan, replace the tranny filter (assuming the tranny has a serviceable filter..ashamed to say that I am not sure if it does), and refill with the proper fluid to the correct level. You should also check the transmission cooler lines to make sure that they didn't get kinked or crushed during the radiator replacement.
Inspect the fluid that comes out, make sure that it is still red and doesn't look or smell burnt.
Then go from there.
how can i tell if it is light fluid, and how can i adjust the fluid level
Jordan,
It explains how to check fluid levels in the owners manual and in the factory service manual. Automatic transmission fluid (ATF) is a bright cherry red.
At this point, I would go back to the shop that did the original service and complain. It is possible that you're fluid is not at the proper level.
