Permanent or removable
Reidsville, NC
I recently purchased a trailer to carry my rtt, I am having a local guy build a rack for it. My question is do I have the rack built to be removable, cons being it can sit a little lower and I can use the trailer however, whenever, or do I have it welded permanently, it would sit a little higher as to allow me to haul anything under the rack (lawnmower, 4wheeler,etc.). I am having the tongue straightened as well. Thanks for your input!
id say permanent you can always remove just the RTT. baybe hte cross bars only with uprights and front to back welded for rigidity without a massive structure your builder will have to give you plans. but if it was me building my bolt on would be heavier with more mass as it would stand alone.
I went with removable, has 3 different settings I can pick from. Used the setup this weekend and everything went well. Trailer pulls/tracks great! Since I was already getting the rack built, I also had the tongue shortened 6 inches.
