I'm posting this in hopes that someone might recognize the problem or have some idea's on what it could be before I jump in deeper than needed.
The problem is what I refer to as bogging, at more than say 20% throttle and from about 1800 rpm to about 3000 rpm the engine wil bog. Increasing throttle dosn't help until high 2k - 3k and then it will start to pull strong and well right up to redline. If I advance the ign. base timing it reduces it, and if I bring it up past 15 degrees the bog begins to disappear... but it still dosn't pull like it should.
My 93 FZJ has a mildly built engine. The basics, it is bored to a 4.6L, the block and head were shaved/resurfaced and brought compression ratio is roughly 10.5:1. The head has a basic porting job, polished combustion chambers. The intake manifold is ported, with a little work to the exhaust manifolds, custom dual exhaust.
Things that were done during build.
Moddified timing chain guide to remove slack from the chain created by shaving and keep stock cam timing.
Had 12 injectors, checked spray pattern on all 12, installed the 6 best.
New wires, cap, rotor.
Plugs are one range cooler and gapped. Pulled all 6 to read and things look to be burning well, maybe slightly lean.
There are no codes, just the quick flash for all is good.
I plan to check TPS, air flow meter, cam timing, etc etc. Any other idea's? There are no vacuum leaks...
