By request of ATS4X4dotcom
I thought I'd post a pic drawn in autocad to help explain what I was talking about.
When you tilt the axle by either installing CC bushings the standard 1 up 1 down way or tilt the axle on the rear bolt you shift the axle in relation to the rear frame bushing.
In ATS's case he did both. In the drawing below the black drawing represents the stock axle as positioned on the arm. The one in red is the position after both the CC bushings and elongating the front hole by 14mm.
I overlayed them in their correct positions so the shift is more obvious.
This technique basically shortens the distance between the axle's center and the frame mount and why repositioning the rear frame bushing is needed to get the tire back in the center of the wheel well.
Now Im hoping they can start thier own axle centre line thread, save them posting them all here.
