PCV Valve?
Blenheim, New Zealand
Hi all. I'm after some help to be sure I've correctly identified the PCV valve. Is it mounted on the side of the block below the No6 cylinder spark plug? With a vacum hose running across the top of the engine to a vacum port on the inlet manifold below the carb? If not, what does?
I've got a problem with LOTS of smoke from the exhaust on long downhill runs under engine braking. I've replaced the valve stem seals, which improved things a little. Compression seems OK (120, 105, 120, 115, 120, 125), but I guess there could be a bit of oil getting past the rings. Before I pull the head, I just want check all the simple things. It seem this PCV valve (if that's what it is) could be letting the manifold vacum drag a lot of oil direct from the crankcase into the cylinders if it's not working properly. Please tell me if I've got things wrong, but is there something here worth checking before I get carried away with more expensive stuff. I should add that it's a New Zealand assembled 1983 FJ40 (2F) with no emission control.
Thanx, and Merry Christmas
Have you performed a wet compression test (teaspoon of oil in hole) ? That will definitely tell you whats going on. I would suspect it if you have already done head work to it.
How steep is the downhill, and how much oil do you typically keep in your crankcase? Steep downhills and hi amount of oil in the pan can move enough oil to the front of the pan [the shallow end] to splash up on cylinder walls, burn and come out exhaust.
If it were valve guides [hi vacuum on deceleration] then you would smoke on a engine braking decel on flat ground too.
Just a thought.
andrewfarmer said:
mine did that - it was broken rings.
Broken rings should smoke going uphill. Ahh, I can still remember those days on the old F135!
Broken rings can smoke going up or down hills, or any other time. Depends.
She smokes a fair bit bit when she's working hard, but the big smokescreen is on a long steep downhill in low first or second. Affectionately known in the club as "Smokey".
I'll do a "wet" compression check. I assume a significant increase in compression over the dry test will confirm I've got broken rings? If so, am I causing damage by continuing to run it, or can it wait till the budget allows?
Thanx
