Pcv install
north carolina
Not sure this will help anyone or if it's even been discussed. So long since I researched the pcv DIY.
Just changed both hoses, grommet and valve in my lx450 with 146000 miles on it.
The hoses were splitting and if you knocked on them with a screw driver it sounded like you were knocking on metal that's how stiff they were. So I knew the grommet was going to be stiff and I was worried about losing some in the engine as it broke apart.
So what I did is got my smallest flat head and pick, I also grabbed my large wet and dry vac. And as I pried up on the rubber any small pieces that broke off were instantly sucked up into the vacuum.
I was worried a 5 minute job would needlessly become a long one, so I'm happy.
Good idea using the shop vac.
If you tear Grommet out before doing the Valve cover gasket you can remove the pieces that fall inside.
I replaced my hose with Gates and picked up an OEM PCV on Ebay.
They aftermarket one I wanted to use leaked air when I blew thru it.
The OEM grommet is made by Inshino or $5 on Ebay search
Inshino OEM Honda/Acura Made in Japan PCV Valve ""Grommet""
I freaked out when parts of my old grommet fell into the valve train... Luckily that little baffle prevents it from going all the way in there. I picked them out with a needle nosed pliers.
I got the grommet from Cdan for 4.03 and the valve for 5.05.
The hoses I got from my dealer. 11.27 for one, 14.84 for the other.
Also picked up oem belts from dealer. 6 bucks for 2 alt. belts and 14 for ac but that's a thread for another day haha.
Good price! How much was shipping?
Shipping from Dan was about 11 dollars I think. I also got vacuum line and egr modulator.
From my dealer no shipping costs. Just order online and pick up at dealer.
They have the pcv valve for I think 4.60
