Paul Is DEAD
I'm not having any issue getting it to turn... It's never going to unscrew if it keeps spinning. It seem unusual that I would need to grip the back which closely resembles a thick washer with a pair of chanel locks. That just doesn't seem right to me??
not really sure...I've replaced 2 radiators (in 2 different 80s) and haven't really had any problems...
what's all that orange stuff on the screw and nut? maybe you might want to get some of that off of there before going any further...
have you tried any penetrating oil yet?
Maybe the rubber cushion dried up so much the bolt and nut ended up loose?
Can you get a pry bar with a split end underneath the rubber and pry to stop the turning? Or use Vicegrips instead of Channellocks?
Been a couple of years since i did mine, so can't remember how much room there is to work. Not so much IIRC.
Vise grips or channel locks work to hold it. On my son's 92, I welded a nut on it (off the truck with the rubber removed) to make removing and tightening it easier.
That's the orange stuff... It's PB
Funny you mention pry bar. I most certainly did think of that :cheers:. Somehow I managed to loose surface area and the pry bar went flying back and into my face :(. So, that didn't work out very well. I probably need more powerful tools :hillbilly:
^^^ This. I didn't have welding equipment when I did my radiator (still don't...). I used a vice grips to take it off then used a 10mm screw (maybe 12mm? can't remember) and used a new rubber washer.
How'd you do it?
I used two vice grips. Larger in the engine bay to clamp the rear of the "bolt/washer head" and a smaller set to turn the stripped/rusted bolt. It caused no damage to the "bolt/washer". It seemed wrong but turned out to be the right choice. Thanks again everyone.
Happy to hear you finally got it loose. It's a pain in the butt period.
