Pattern check on new 4.88s
Mt Juliet, TN
Alright guys, I'm in the process of installing 4.88s in my 80 and I need your expertise. How does my pattern look?
This is the rear 9.5 factory locked diff, I reused the factory shims as starting point.
Backlash is .0075
Best to get @gearinstalls.com opinion. Zuk or Ken, does Toyota (& others) diff work. The quality of his work is awesome. I would trust his opinion above any, at this point. If he does't chime in I would PM him.
Edit: His website, just in case he doesn't respond.
check this video out. He breaks it down pretty well and shows what the pattern should look like.
........check this video out. He breaks it down pretty well and shows what the pattern should look like.
That's a great video to help understand the concepts, but I'd caution OP to get Zuk's opinion on the pattern. It's obvious that pattern shows shallow on coast side with pretty much centered heel to toe. Drive side is not centered heel to toe - too close to toe and also a bit shallow. Camera angle can deceive sometimes. They're good quality photos, but the angle, for me, is hard to see centered heel to toe. I still would communicate with Zuk. It would really suck to get this wrong, IMHO.
I'm curious what the pro's say, but to me that doesn't seem bad. Then again I've been through a few of those and am heading to beefier (14B & SD60) axles.
Both the pinion and the crown gear have more strength with a pattern further in towards the center of the gear, but the further in you move the pattern on one, the further out you move it on the other, so it's a compromise towards the middle ground. But not all patterns work out perfectly and you sometimes will compromise the stronger one for sake of the weaker one slightly.
As to the "heel to toe" comment, I'd be inclined to remove a few small shims off the pinion and then see how it patterns, but then I'm not a pro for setting up gears. Interested to hear what Zuk says about it if he's has a comment to add.
