Passenger side Parking Break cable seized up
Boulder, CO
Hi Everyone,
For whatever reason the passenger side parking break cable has completely seized up, Can't move it at all from the rear wheel, other side is fine.
My question is, has anyone replaced one of the two parking break cables and how much of that center console needs to be removed to access the cables attachment to the parking break... I know removing the cup holders gets access to tightening the nut, but not enough to remove the cable.
Any guidance would be great.
I suspect you are in for a lot of work. IIRC there is only one adjusting nut at the brake lever, but it quickly splits into two cables that exit the transmission tunnel and run along the inside of the frame rails. I'd have to give it a look but this may require fuel tank removal to R&R the bad part.
Was able to complete the job in about 3 hours with new parking brake shoe replacements on each side. Getting above the fuel tank required some creative thinking, but in the end we prevailed. I finally have a fully functional parking brake.
