Passenger Door won't open???
I love my FJ80 except for 1 thing I cant get the passenger door to open? My Passenger door FJ80 1990 won't open with either the remote or key or either outside or inside handle? The window's fine if you wanna Starchy & Hutch it but.... Can't get the interior door trim panel off due to non opening. Can't get to the anythying inside the door? Parked it & it was fine an hour later won't open? No obvious s=igns of breakin? Key & drivers door master switch & remote make all the right noises it just open the open the lock? Any help greatly appreciated.
This forum rocks with all the help, hasn't anyone else had this prob?
Any advise at all greatly appreciated!
Lots of us have.
Search and you'll find plenty of threads about how to get into the door when it won't open, and what's usually broken inside. I think there was even a full write-up recently.
Basically: Yes you can get the trim partially removed and out of the way enough to get your hand or a screwdriver in there, pop the lock, and then finish up with the door open. The problem's usually just a little broken spring that can be replaced with one from the hardware store.
Feel free to ask if you can't figure out how to use the advanced search effectively; you're really doing yourself a dis-service otherwise.
Welcome,
Curtis
Why will the door not open w/ the key? If it is a worn out key, get a new key cut. Small problem is the key code is on the passenger side door lock cylinder. When you get the door open take the cylinder to the toyo dealer and get a new key made...You wont have the problem anymore, and your rig will love you for it since you will eventually botch up your ignition cylinder using a worn out key.
If it is the mechanism that is another problem.
Good luck.
Thanks Curtis, I have had to lever as much of the interior trim as poss off the passenger door & yes I can get down into the lock area feeling by braille. I took off the drivers panel so I know what I am feeling for. Basically the lock is permanently engaged in the locked position. In the drivers door is the green electronic brain maybe somethings not triggering inside of that? I have disconnected the 3 attaching rods to the lock & jiggled everything that I can get my fingers onto but nothing moves? Can you send me a link to the advance search with the article you spoke about? The FJ is definately a July 1990 model but it's RHD in Australia sorry for the confusion CJF. I have fitted big wheels & an electric supercharger to the 4 liter motor got better economy but increase in HP????? Still wondering. Maybe it's because no one here can figure out what wire is the IAT sensor wire, presumably it's built into the Mass Air flow unit. Pretty sure they are the same in the US. Did I mention I'm a California native down here on never ending holiday?
Thanks for the replys It's a bit more than a lock smith job as the key & remote work fine & it's definately something inside the lock unit. I drilled through the door jamb level with the strike plate & it's fully engaged & not wanting to disengage with anything I can think of???
Cheers Simon.
Not to hijack, but.....an electric supercharger on a 3FE?
:lol:
Those aren't very reliable for anything. You're not gonna get much power out of that motor unless you plan to overhaul it with bigger pistons/injectors/etc/$$$$/etc and such.
A "cheap" power booster for this motor simply does not exist.
[/hijack]
EDIT: Good on ya for getting better economy. :cheers:
And welcome to 'Mud... :flipoff2: <---official 'Mud salute
Yeah I think I got more 'sound' but no more HP from the drone of a motor. Anything would be an improvement but I can't justify the $$$'s as I'd be better off going the turbo diesel route on a different vehicle down here as gas price are 3 times what they are in the US. There's quite a few down here with chev motors that could be interesting.....
Thanks Curtis and Ben, really helpful for getting me this link. I now have a door that operates like.. well a door.Yes it was the spring although down here with the currency difference it was 68 cents so a much more expensive repair in the southern hemisphere! But again a big thanks for helping me out from the other side of the world! Now if I can just figure out how to find the wire for the IAT sensor???? Cheers Simon.
