Pass window ..
@landcrshr Where did you get the EWD that is so nice and clear and in color?
I have a black / white copied manual that is less than visible and it is too hard for my old eyes to read. I have to say, these are the hardest EWD I have ever read. I'm just having a hard time following them.
My window problems is that the PS windows will roll DOWN with the master, but not UP. Both of the PS switches work fine. I've checked the plugs again and they are tight.
I guess I will have to go through this troubleshooting the same way.
Yours sounds like a master switch problem, if the window(s) work in one direction, the harness should all be good.
My hard-copy EWD is photocopied black & white too. I downloaded the '96 PDF version here, from @ElPolloBlanco I believe.
They are hard to comprehend at first because of all the little bubbles and boxes with numbers. It pays to study the "how to use this manual" section, and then keep it on the night stand for your bedtime reading.;)
I would do a continuity test between pins 1 & 5 (key off, door open)
Should be close to zero Ohms when the "up" switch is activated.
That's black orange and black in your switch ( pic you posted ) ..?
#1 is the black wire, #5 should be the blue/black wire you tested earlier for 12 Volts.
You guys are not gonna believe this, while testing continuity ( was reading 40 plus ohms while going up) the swith activate the motor up and works!
Hey, problem solved!
Let's hope for good.
I try it yesterday couple more times .. it worked random .. kinda lost at this point .. !
If I want to make it work with no switch ( jumper on the plug ) to isolate if it's the switch or not .. that makes sense .?
As I said I've tried couple of switches .. could not believe all have the same behavior ..
[/QUOTE
Then go ahead with this:
You could remove the black/orange (pin #2) wire from the plug and apply 12V there (to the plug).
The important thing to know is that when the window motor is idle, both motor wires are grounded. The ground is supplied by the master switch assembly, so the circuit has to be broken between the DS and PS before applying +12V to either motor wire.
that means I need to disconnect the plug between the master switch and the pass window switch ..?
Windows will work ( this test will work ) disconnecting the master switch .?
Many ways to test this.
If you wanted to merely apply +12V to test the "up" switch, then you just need to remove that black/orange wire from the plug on the PS switch. Once that wire is out of the plug, it will be safe to apply +12V to the plug where the wire used to be.
With this setup, activate the "up" switch and see if it works. Then try applying the +12V directly to the black motor wire. This should definitely make the window go up.
I realize now I didn't quite get this right:
When you apply power, the window should immediately go up, so be sure to have the window down before disconnecting any wires.
As @BILT4ME put it, the EWD can be hard to read, so I finally decided to generate some simplified diagrams to help understand the power window system.
This one shows the basic concept of how one window is controlled with one switch, as the driver's window:
This is how another switch assembly is added to the circuit:
This diagram shows the basics of the circuit for the two front windows:
And here it is in detail, as it actually exists:
In PDF:
I hope this is useful.
it is and a lot .. on a related note, I have the jumper to have permanent 12V to all switches .. so I don't need the key
Back to wiring .. if I apply 12V to the black it will go up and if do to the red, will go down ?
After more testing,it turns out ( I'm 100% positive ) this issue it's V related.. more V ( like engine running ) it works both ways. Drop in V to battery V and only goes down ..
And still, only when using the passenger side switch?
When I first bought my truck, the LR window was intermittent up or down. I swapped switches from the other doors into it with no results. I ended up buying a new motor to find out that it didn't fix it. I had since taken out the regulator and motor, waiting until I had time to thoroughly diagnose. I secured the window in the up position with zip ties.
As time went on, the right side windows would work only occasionally. Usually, they would go down, but not up. I then rebuilt my master switch and I got it so my RF window would go up AND down, but the RR would only go down.
I rebuilt the master switch AGAIN, this time, looking at all the little rockers in the switch, cleaned off all the burnt edges, and bent all the rockers to the EXACT shape of the rockers on the one window that worked. Afterward, I had all 3 windows that would work up AND down.....for 3 weeks. Then it went back to down but not up.
That at least confirmed for me that it was the MASTER switch causing my headaches. I bought a new master switch from Switch Doctor last week and installed it on Friday. All 3 windows work up AND down again!!!!! (I still have to reassemble the LR door to see if it cured that one too...)
My point is, this may be your MS and not you individual door switch. And for $45.....I was willing to gamble that it would work... and it DID!
Yup ..
It always works up or down if controlled / operated from master switch ..
Did you get a chance to inspect that connector in the right kick panel?
You may have a voltage drop there on the contacts for that blue/black +12v wire.
Totally forgot about about that .. how this connector should looks like .? or only should be this one there .. ?
Just the one, squarish connector.
The wire you want is in one of the corner positions.
