Parts list for Timing belt RR on 01 Sequoia
Virginia Beach, VA
Hi folks,
I'll be replacing the Timing belt on my wife' sequoia and need to make sure I don't forget anything. I have done timing belts on 4 cylinders and on the 5vz, but never on the 2uz.
So far this is what I have
Timing belt
Belt Tensioner
Water pump
Drive belt
Thermostat
new coolant
new hoses
idler pulley for TB
I know that it is common to replace the fan bracket on the 1uz engines; is it also recommended for the 2uz?
Thanks folks!
Dan
That's a pretty solid list. I also recommend upgrading to a Goodyear Gatorback serpentine belt and possibly doing the serpentine belt tensioner as well.
I had to replace my wifes fan clutch too, but that is because it was beginning to lock up literally the day before I ordered my parts from Cdan.
Some people recommend doing the cam seals, but I didn't because they looked dry at 195K. They're worth a look while your in there, however. If they're dry, your good.
Other than that, it's a pretty good list. The 2UZ is pretty easy, just lots of crap has to come off. So if your organized, you're good.
Edit: I also recommend the idler pulleys.
call "cruiserdan" @ 800-432-6668
he's in the 80 series section and is a wealth of information and will get you the parts you need.
Tell him you are on IH8MUD and you get a discount too!
Thanks.
I am well acquainted with getting parts from cruiserdan. I just figured I would ask the resident experts from this section before bothering him again.
Dan
I got an 01 tundra with 72k on it now.. so I will be doing this soon... well not that soon... but can you give me and est. on what you spent for those parts listed above.
