Parts identification help
Pulled the interior in prep for some work to be done and came across some things that I need some help figuring out.
Found this bracket laying loose in the rear quarter panel under the factory jack bracket holder. Not sure what it is for or where it attatches to.
I also found these tubes in the same area that aren't connected to anything. Is this a vent tube or is it meant to be hooked up to something? Found a second tube as well in the same area of different diameter and material also sitting open to the rear quater panel storage.
Lastly, I noticed that the DS rear quater panel area was significanlty more dusty than any other area in the Land Cruiser. After pulling the carped I noticed there was an open hole in the floor. Is there a plug that is supposed to be here? If anyone knows the part number for it as well that would be super helpful. Sorry for the poor image - camera shake.
First pic is a "shield" that goes on the fuel filler door release mechanism.
Black tube (with orange arrow pointing to it) looks like the breather for your rear locker actuator.
That's about all I know for sure...
I hope some of the gurus chime in because I have the same hoses just hanging out in there. My rear windshield fluid spout doesn't spout anything, so that is what I had assumed the hoses with the "y" were. My truck has had a questionable past though so anything is possible.
well fudge. And, Thank you.
Thanks for the help. I was wondering if they were leftovers for different models. The bracket guard makes sense. I'll have to see if I can find the bolt that holds it too. As far as the diff breather - maybe that is what it is but I thought I removed it when extending the breather lines back when I got the vehicle 10 years ago. May be I didn't remove it all the way.
That hole in the floor should have a plastic or rubber plug, I forget which
for that hole. There is also a large grommet inside the bottom cavity of the quarter panel facing inward which can come loose, a ton of road dirt will blow in
if that grommet is missing. In models with the port installed trailer harness running to the the tow bar, they often run that harness out that hole.
Thanks @Kernal. I figured it had a plug missing. I'll look in the quarter panel too and see if there is something else missing. I am guessing there is as it seems like that is where the dirt is coming from instead of the cargo floor area.
There is no separate bolt that holds it on, I don't think--it just sandwiches in where the plunger bolts into the body. In the "U" shaped part of the guard.
Thanks, I'll take a closer look when I put it all back together. I couldn't find a missing bolt when searching - glad to know it didn't exist in the first place :)
As far as the black hose goes that I couldn't identify that is marked above with the orange arrow, it definitely isn't a diff breather. It feeds down under the frame on the DS and follows along the wire loom to the front. I didn' trace it to where it ends up. Still not sure what it is. The 1st photo shows where it leaves the quarter panel and comes under the vehicle. The second photo shows where it joins the wire loom/conduit and runs forward.
I also found another mystery wire - l suspect it is a part of an aftermarket alarm or something but wanted your guy's thoughts and wanted to make sure it wasn't something factory that was cut. The joys of owning a previously owned vehicle.
It was found under the steering wheel/instrument cluster - above the brake and gas pedal. Thoughts?
View attachment 1995958View attachment 1995959
Aftermarket, added ground, for something...
It was stated as a diff locker actuator breather not just a diff breather. Even if you don't have factory lockers the tube is still going to be part of the harness.
Got it. I misread the post. Didn't know diff lock actuators had breathers. Good to know.
Figured it was aftermarket. I'll be taking it off.
