Parts from a 64 FJ45 LB Pickup
I had to reread the first post, thought this was a part out deal. I see what you are doing now.
I need a vin tag/title for a FJ45 Short bed or an LV. For a buggy project.
Mike, I would be interested in the fuel filter. Also interested in the fwd control cable with the knob if available. Also interested in the water pump as a core and the lower heater t-pipe [between the water pump and the bottom of the radiator.
If you're pulling the wheel, I'd also be interested in the horn button and all the contact parts behind it.
Thanks.
I don't mean to waiste your time but are you willing to part with any rear swing 0ut doors and tire carrier. thanx,
Rachel
I'm interested in the steering wheel. I can Paypal now and pick up in June/July.
Thanks.
Mark, I have pending sales on everything except the water pump and 't' fitting. Water pump may not be good enough for a core but its yours if you want it as well as the fitting. Fitting is still attached to the pump. Pump is frozen and won't turn. It also appears to have been cut in the snout area. Not sure if this is a stock thing or not. I can try to post a pic if you want to see what I'm talking about.
thanx anyways
Mike, I am a patient man. Hit me offline when the dust settles and I will take what I can get that is left.;)
