Parting Out Parting out 2H
Spun a bearing 3 years ago, been sitting since. But all injector pump, glow plugs, starter etc should be good. I have an extra original set of 6 volt glow plugs as well. Also have the bell housing that would work for the 12HT. Alternator is aftermarket.
It came out of an HJ47, 1981. It is 12v.
Well, good questions.
2H bellhousing & cover $300
12v Starter, almost new, $70
Glow Plugs - 6V (OEM in hj47) or 12V (actually work to start the engine with momentary switch) $15
Injection pump - $400, was serviced not too long ago
Injectors - #60 each, have 12 (I think no one could figure out why it would not start, someone spent a bunch of money on fuel system)
Injector lines - $100
Fan - $40
Fan Shroud - $50
Radiator Bracket - $80
oil pan - $150
Motor Mounts - $50
Let start with that, if anyone is interested in the internals or block, just ask.
Fan - $40
Fan Shroud - $50
oil pan - $150
Motor Mounts - $50
All the turbo stuff is gone.
Starter still available?
Do you know if it will work in my 1982 BJ42 with a 3B engine?
It is an Aussie 12 volt
Fan - $40
Fan Shroud - $50
oil pan - $150
Motor Mounts - $50
Do you have the sedimenter, and if so, how much?
4wd emblem on rear, if so, how good of shape (a pic would be good) and how much?
license plate holder with light domes? how much?
How about the dip stick?
still interested in starter
Are you dropping in another H?
Looking for 2H motor mounts
