Parting Out 1985 Tan Fj60 in Phoenix
Silverton Colorado
Parting Out 1985 Bronze Fj60 in Phoenix
MAKE OFFERS ALL THIS STUFF MUST GO ASAP- MOVING SALE
It is located in Phoenix AZ, I am headed to MI. from AZ. on the 11th of AUG, so I can deliver some of the larger stuff to you. Make offers it all must go!!!!!
-Still to go-
-Cargo area glass (both sides) $50 ea.
-Rear hatch glass $60
-All doors (factory copper color) with glass, handles (except driver window handle), complete with hinges! $50 ea.
-Front axle housing $100
-Rear axle housing with sway bar mounts $100
-2 third members stock 85 60 series $100 ea.
-Rear axle shafts $25 ea.
-Front shafts and birfields $50 ea.
-Front seats $50 ea.
-Back seat upper and lower $100 for both
-Leaf Springs, full set of 60 and 62 stock spings $150 per set of 4
-power steering box w/pitman arm $75
-Pair of stock 60 chrome wheels $40 for the pair
-Rear seat belts (brown) except pass. male end $20 for all
-Steering column with ignition key $50
-Gauge cluster w/206k on the odometer $20
-E-brake lever, floor mount, and floor section it mounted to $10
-Back seat floor carpet section (brown) $20
GONE:
Front markers
Right rear cargo area panel
Cargo area Floor carpet
gas tank
How much for the front locking hubs and the smog pump?
I will have pics of the Passenger seat and Driver rear fender uploaded later. The Driver seat has a bad tear on the door side vinyl so only the frame is good, the pass. seat has one quarter width tear in the center of the seat and I will include pics of the seat and tear. The fender has minor surface rust in the usual areas, but hasn't eaten through (I can sand and treat the areas if you want it)
My wish list -- 2 front hood bumpers, DS front turn signal gasket, forward dome light, rear cargo panels, PS rear marker light, possibly rear shoulder belts. Mudship to Abq?
I have the forward dome light if you want it, and the side rear cargo panels. All else was gone or wasted.
parts
I need both front side mount mount yellow signal complete assemblys.
If the interior is brown I need cargo area right side panel and carpet if good.
Trim around radio.
Trim around radio.
I have the rear carpet (brown) and the rear cargo area right side panel. I also have both side marker light assemblys.
