You are second in line on the grill and valence.I want the grille and lower valance (houses the front turn singals)
how much to ship to 36832?
I don't have running boards. Not sure what clips you are referring to. Can you describe or post a picture?
Here are a couple of pictures. The clips are similar to this one. These actually came out of a toyota corolla. But they go into the clip/molding strip ontop of the door(below the window). If you can remove all of them from all the door/windows and if they are not damaged, how much shipped to 55434?I don't have running boards. Not sure what clips you are referring to. Can you describe or post a picture?
what is the story on the center console?
I need the clips on the bottom of the windows that are outside. Are your running boards in good condition? If they are, how much shipped to zip 55434?
Driver fender is straight - only damage is one of the flare mounting studs pulled halfway through. It would be covered by the flare, so easily fixed. Paint code 6M1. No flare.
In phoenix
