Partial stereo install
Florida
...just finished up some loose ends on this install...awaiting more parts to the puzzle by mid week...then I'll have the amp hooked up and the powered subwoofer...
The sub will live in the stock location...it's a Rockford fosgate pw8 ...copying the install idea from Moog
https://forum.ih8mud.com/threads/an...option-in-stock-location.863973/#post-9798301
For midbass/midrange I chose two sets of soundstream stealth component speakers...they come with passive crossovers and the woofers are very slim and will not interfere with window operation...the downside is you have to trim door panel and sheet metal to accommodate the larger diameter speakers...
The crossover lives within the door panel in the little cubby that's molded into the weather proof plastic liner beneath the door panel...just attached them with 3m vhb tape....mounted the tweeter up high on the small black plastic triangle but the door mirrors...
Went with a single din head unit from pioneer...deh x9600 bhs...has blue tooth..HD radio..cd..USB..XM and so on also has an aux input so that I can connect my HF radio through the system
I have mounted behind the 2nd row seats a soundstream nano 5 channel DClass amplifier which will eventually run the door speakers ...for now everything is run through the oem wiring using the schose harness adapter
