Part-time 4wd mod commentary
Kentucky
Came across this...
...a comment to a video covering a 105 series inspection....fwiw.
Rob Kay
Rob Kay 6 days ago (edited)
Hi Andrew Being the designer of the part time 4 wheel drive kit l watch with interest The kit was originally build for early 80 series as they suffered for front end problems Such as inner axle seal leaks spline and drive cap failure and cv noise These problems where fixed in late 1992 when Toyota upgraded these components Fuel savings some people said it did and some didn’t Our Dyno testing at the time show that that front drive line used 7 kilowatts of power to drive Which is about the same as turning the air conditioning on You will need some centre diff parts to convert it back Also check the clutch plate is a genuine one as it has an anti rattle mechanism in it To stop transmission rattle at idle and low speed just like the noise in the vid Cheers Rob Kay
The video is here:
The relevance to the 80 Forum is that the 105 series is an 80 chassis and drivetrain with a 100 body. This is a drivetrain mod, so thought it worth consideration to those thinking of it. I neither run the mod nor hold an opinion.
