part time 4 wheel
EarthX
Owner of Earth Exploration Technologies
Lake Arrowhead
I need some some help!
Im putting some '94 fj80 axles under my fj60 which means Ill need to convert the front axle to selectable hubs. Does anyone know what parts Ill need to do this and where I could get them? Is there a kit available to do this? Thanks for any help.:cheers:
Use any toyota pick up hubs 1981 to 1985 only the stright axel hubs will work. Not the IFS!
thats all it will take , no biggie just bolt them on.
Thats a transfer case part-tme part, the 80s r full time 4wheel .
That kit is to "part time" an fj80. but since u r just using the axels u wont need that.
U should just need to replace the "lock out plates" with the toyota pick up hubs.
Hope this all makes sence, my typing skills suck!
HMMMM... im not sure about the 60 hubs, they should.
I used a set of 80 axels under a rock crawler i built and i used the pickup hubs, so i know the will work.
I think the 60 axels r the same as the 1991 and 92 80s, NO??????
Mor4wd,
I may be wrong, but when I researched converting my front axle to Aisin hubs from a soild axle mini, I thought the 94-97 80series axle required a .100 spacer or shim, for them to work correctly, the 94 and later Birfs had longer splines (.300) for better engagement and less wear to the drive flange....search "part time" or "Aisin" in the 80 section to confirm, should be some info for ya.......
chris
Mor4wd,
chris
yes, there are 2 different cvs, early and late.... the late cvs have a longer spline by about 6mm.
a - early hub/late cv
the cv will be able to move in/out, making a mess inside your steering knuckle... been there done that.
b - late hub/early cv
i am sure you wont be able to fit the cvs spline circlip.
Well now Im confused? Can it be done?
Use the ones off your 60 and be happy. Put a shim in between the hub and the C clip on the birf if needed and forget about it. 94 birfs can both ways, they came in long and short. The long ones will have too much slop if you don't use a shim. Put them on and then pull on the birf and see how much play it has. If it has a lot of play shim it out. You can use one with a drive plate to check to see how much play it should have. I've done this before, it is very easy.
