Part # for Engine-mounted wiring harness clips
Austin, Texas
Trying to locate a part number for the clips circled in the attachment picture. Clips are both broken and do not show visible part numbers. As I understand it, there are several different clips with diameter range given on the clip themselves, but I cannot find those numbers on these clips. Anyone know this part number? Thank you in advance.
7mm = 82711-24010
10mm = 82711-2A420
13mm = 82711-2A600
15mm = 82711-2A530
20mm? =
25mm = 82711-3H180
28mm = 82711-20870
I know it’s an old post… sorry! But I found this list of awesome info and figured I would share with you! These are the part numbers for the wire harness holders that clip onto the metal tabs. If you remove your old one there is a number on the bottom. Use that number to order the right ones. For example, if you have a 10 on the clip, order the 10mm!
