parking brake snag
Clemson, SC
I have put a 4 speed tranny and 4 speed t case in my 68 fj 40....and i have run into another snag...I was gettin ready to bolt the parking brake on and I had to get it around the cross member...well that wasn't too hard but then I was gettin ready to put the cover on and I looked at it and it doesn't look like it will go on with that cross member in the way.....What should I do.....my thought is is to cut out a chunk of the cross member or cut it out totally and weld it back a few feet towards the rear of the cruiser? Thanks for the help!
The crossmember is a problem. Rather than cut it, you can remove the bellhousing mounts from the bellhousing and drop the whole enchilada down enough to service the PBrake. It sounds like a big deal and if your exhaust is hooked up it will be a bigger pain, but I'd still do that rather than cut the X member. Poser said that a some will cut the x member close to the inside of the frame rails, then rotate it back enough to allow clearance. Alignment is accomplished by sliding a short length of suitably sized pipe(that fits the ID of the x member) in from outside the frame rails, then weld it back.
GL
Ed
As Ed suggested, you CAN get everything in there if you tilt the powertrain down temporarily while installing the drum.
I had the same issue when I put the 4 speed in my '68.
I cut the tube.
I welded steel plates to the inside of the frame a few inches back, after drilling and tapping them ahead of time. Made matching plates that I welded to the crossmember. Bolted crossmember back into the frame.
Is it as strong as stock. I don't think so.
Has it stopped me from wheeling the piss out of the truck set up that way. Heck no.
Hth
Mark A.
