Parking Brake Compatibility
Illinois
I have a 67 FJ40 with a 76 F2 motor with 4 speed. What is the best way to hook up parking brake? Do I need to change the mechanism in the interior. Would like to leave stock handles etc. Thanks
Your existing parking brake cable should connect to the parking brake drum on the transfer case just fine.
Great. Thanks pjohnson. Do you know what the differences are in the cables? Thanks again.
Do you have a parking brake lever under the dash? Is the cable present under the truck and not attached or ?
The only difference I am aware of is the mount and hole in the firewall could be round or square depending on the year. The connection to the parking drum is the same throughout (I think). Others will know more.
