park/neutral position switch
tdfox
Rover31 Jedi Master
Central WA state
ok Gurus here's the deal.
Cruise control stopped working this past summer.
Did a bunch of trying to figure it out with no luck.
One day this sumer, out of the blue the rig stays in low gear but the indicator says D (drive). So the park/neutral switch comes off and gets "adjusted". All is well but still no cruise control and one day it pops into low and a half mile later its just fine.
Now we come to this past weekend.
the rig is driving fine but the gear indicator is saying R when in R and, when in D. A bonus is the backup lights are then on! again no cruise control.
So my question is this, time to buy a new park/neutral position switch or do I take it off again and try to "fix" it? Will it work for more than a few months? Think my Cruise control will work if I replace it?
Is it something else?
Thoughts? part #'s?
Thanks folks
T
Guess I forgot to post, thanks to the wonderful folks here I was able to try and fix the sensor and the cruise. Yes I have used the search function found lots of great info tried many many things. Since I have never seen a post like mine, Now I am on to the next step. Any other suggestions to the questions I posted?
Thanks
It would help if you supplied basic information about the truck, such as the year and country of origin. This will determine what engine/transmission combination you have. Some maintenance history would be OK too.
On most if not all, the NSS runs the dash tally lamps. If your dash lamps are showing the correct transmission gear and jive with the shift position, then chances are the NSS is close to correct. Follow the adjustment procedure in the FSM to get it correct.
On later models, the transmission shift position is fed back to the ECU. On earlier models the transmission is fluid controlled.
Doh yeah that would be helpful,
It is a late 95 OBD II. Dry climate living for the last 10 years, Lots of good maintenance has been done by me or by Tor (yes he is the awesomest for your cruiser). Axels rebuilt, tranny flushed and oil changed, PHH has been done.
I have done all of the checks in the FSM with nothing coming up as the culprit. the cruise control check was all normal.
Just the symptoms that I wrote of earlier. The sensor was taken off cleaned looked over tested (good) put back on and worked. Now this. I am thinking I need to order a new switch but then I read this,
"On later models, the transmission shift position is fed back to the ECU. On earlier models the transmission is fluid controlled."
What meaning is that for me?
Yes I have searched and searched
Did you adjust your NSS according to the FSM?
If you shift the transmission manually, does it shift OK through all the gears?
Has the transmission fluid been changed recently and is it at the correct level according to the FSM?
Has the transmission shift linkage been adjusted?
Yes to all, it was all gone through this past summer when this first happened.
I only can come up with two possibilities, the switch is bad or a bad connection/corrosion issue. The later I hope not as the can be so hard to chase down.
So my question stands, has anyone replaced the switch and problem solved?
Thanks
If the transmission shift linkage was adjusted incorrectly, the shift lever could be off. If the shift lever is off, then the NSS would be off as well since the NSS is driven by the shift lever shaft that goes through the transmission housing.
If your dash tally lamps are illuminating correctly according to the shift lever then the NSS is good. If you can only crank the starter in P and N, then the NSS is good.
but wouldn't that have happened from the start? The rig has run perfect since the 'adjust' this summer, abet without cruise control but that has been for a year or more. To me unrelated, but maybe not, maybe the cruise not working was the first sign of the NSS starting to fail?
All of the issues are sudden. The rig is running driving correctly except for the symptoms in the OP and here.
As stated the dash lamp is not correct, when the shifter is in D the R dash lamp is lit as well as the reverse lights being on. All other dash lights are correct when the shifter is in the same position.
Thanks again keep hitting this thread please.
If you followed the adjustment procedure in the FSM for the NSS and the dash lamps are wrong, then there's a good possibility that the NSS is faulty.
I would also look in the FSM for a procedure to test the NSS. I don't know it off the top of my head.
I would try to get a used replacement from a salvage yard or from one of the many many parts dealers here on MUD.
Jason at Cruiseryard (arcteryx on mud) is a great resource.
Alternatively, sometimes the NSS can be rebuilt. Internally it's a large wiper switch with multiple contacts and a spring loaded wiper.
Yes I do. I have read about that it could be the issue. I am not convinced that is it, would that cause the gear indicator on the dash to read wrong on one gear?
Thanks again for the help!
Ok so off came the tail lights out came the bulbs.
No change! When in shifter is in D dash indicates R. All others are correct.
I am buying a NSS it looks like.
Thanks folks any more ideas Ill be here.
Talked to the OP and only replying because this could help someone like it did me;
BIG shoutout to tdfox for a speedy reply even being idle since oct 18 🍻
He replaced the NSS and resolved his problem
