Panhard Mount Relocation
I don't think most people need or want to mess with the steering until they really lift the truck 4+ inches...
Not sure you really have any benefit to this mod until you step into that world.
Might I ask why you did this mod with such a mild lift?
Typically the reason for the mod is to beef up, raise and set up the steering for hydro.
That generally comes with bigger tires, bigger tires = bigger lift then stock or OME 3".
-A
Hahaha needed to replace tire rod and i have a 5 inch lift hahaha.....
J's don't = 5" of suspension. And suspension is the only lift that will move things out of the way from each other.
Well whet you have 2 inch spacers in the front that double as bump stops it should bet you 5 haha also how other then limiting up travel and easing you rig change anything other then your starting point it's still going to arc the same way just easier to bump and not feel some bump stops haha right?
None..
I have max travel, no adj to bumps from stock.
6" coils and about 3 3/4" up travel before the two would touch.
I have an additional 2" BL but that does not factor into the equation.
None..
Weird I wonder if it binds under flex enough or the coils don't let it flex enough to let them touch... Have you ever hit the front bump stops well more importantly the drivers side? Are those scratches from a pipe wrench or contacting I'll measure mine tomorrow
I'll have to check, some of that is from my oil leak.
so i checked today and right now i have about 3 1/2 till the two touch... and i think about 2 inches more of up travel past that till my bumps hit that are extended 2 inches haha
So if your bottoming out over speed bumps I'd say your coils are too soft or your driving to fast for this type of set up.
One, get heavier coils
Or Two, relocated the frame mount on the panhard.
yeah back to the original post to see pictures... oh well guess ill just have to custom fab one with no ideas hahaha other then the 4wu one... and i can make it bottom around town but as soon as i get into flexy situations off road it relys as the tire rod as a bump stop and already broke a knuckle stud... :(
Subscribed. In same boat, only worse. I put tierod on top of the knuckle, leaving less room. I could go under, but ylink is then wrong side. Impulse buy for me as I mangled my drag link and TREs exploded.
