Panhard Mount Relocation
San Diego
So ive searched and searched for about a week now and cant find very much on this other then the 4WU 3 link set up.
What i really want and would appreciate greatly is if you guys would take pictures of your RELOCATED mounts for the panhard to avoid interference with steering. If your really awesome and include some measurements then that's even better!
This will help people now and in the future for when they search like me! if its heim joint mounts thats even better!
THANKS SO MUCH!
Don't move your Panhard without moving your drag link also. You can mess up your steering and handling pretty quick.
I'd also say if you have to ask you probaby shouldn't be moving critical components. The 3 link stuff all applies to your question
well thats obvious... what i want is to see the mounts people have made... Also as long as you move both sides of the panhard up at the same rate it wont effect how the draglink comes in to play p.s. my drag link has moved with my 1 ton steering... so the draglink angle is alittle steeper.
There's a bunch of pics of mine and Jose's steering in His build thread....
Panhard relo shots also, if I recall... If not I can snap some in the am.
-A
Here are a few:
Thank you!! Do you have any of your frame side mount or did you use the stock one? Cause that's where my problem is with my steering contacting the panhard mount
Nothing changed on the frame mount...
You need to post of pics of what you have going on...
I'm having a hard time understanding why or how your steering is contacting that mount unless your pitman isn't indexed correctly?
-A
the tire rod contacts the mount hard this doesnt show all the chewed up paint because it was before i hit it a ton on a trail. i have about 3 inches of travel on drivers side and like 6 inch up travel on passenger because of it.
Edit****
Are you taking about the links in the foreground of your pic making contact with the frame mount of the panhard?
Ok so I think i understand what your asking now. Just took a break and ran outside to look at mine.
Yes there is the chance you will rub on the upper mount. Only way to remedy that would be to move the upper mount like when you 3 link... So yes you do have some limit in up travel on drivers side I suppose.
But you must also factor downward travel of pass side along with rear body flex / roll...
So what seems like only 6" of up travel is really more with the factors above also playing into the suspension cycle in a non 3 linked 80 suspension...
I have yet to rub mine... But that can be because of the lines I choose, and the way I wheel my rig. Slow and low...
Again it's always about knowing your rig, its limits and adapting to the situation.
Word.
Double post.
Yeah just driving around going over speed bumps or in drive ways it contacts almost dead center. Going as slow as possible in trails i hit. 1 time full flex I contacted and rubbed I line into it... This is why I wanted some pictures of the frame mounted one just to see the distance back and structuring but I can wing it haha THANKS
What lift are you running? I'm on a 6" so might not have the same clearance issues as you describe... You must be close to stock if this rubs on speed bumps.
I can see clearly now the rain is gone.
Ugh duplicate post
okay this is what im working with i can move the axle 2.5 inches forward but then when the prings compress they will be super contorted twards the front an contact the bump stops so thats really a no go and the only way is move the panhard... i dont get how on mine it hits and no one else it does unless they have like a 4 inch bumpstop extension in the front!!!! this isnt full flex since it was on a jack in my drive way on rocks truely scary.... PLEASE help
you can see the paint rub so is everyone just limit there up travel a ridiculious amount with this set up or what?
Yes.
Your limited.
Put a bigger lift on and increase that limit.
Done.
-A
haha sounds simpler then it is..... i guess ill just 3 link it at the same time at least i hope. THANKS for being the only one that has any input hahaha
