Did you ever get the lift dialed in?
It's not where I want it, no. Still Dobinsons Flexi coils up front, 2.5VT in the rear. Rear is sprung perfectly for when the truck is loaded and pretty close unloaded, but the 2.5s lift much more than I'd like. Front is not sprung correctly, and the Flexis have sagged quite a bit. Still very unimpressed with those coils, they don't feel that much softer than the VTs when they're loaded and don't extend well on my truck. Dobinsons yellow shocks are terrible, but no suprise there. And at this point they are so thoroughly cooked they do almost nothing. The Timbren bumps do a good job, I need to shorten the extensions to maximize travel but waiting for the next set of tires.Did you ever get the lift dialed in?
If you did it again from scratch which way would you go?It's not where I want it, no. Still Dobinsons Flexi coils up front, 2.5VT in the rear. Rear is sprung perfectly for when the truck is loaded and pretty close unloaded, but the 2.5s lift much more than I'd like. Front is not sprung correctly, and the Flexis have sagged quite a bit. Still very unimpressed with those coils, they don't feel that much softer than the VTs when they're loaded and don't extend well on my truck. Dobinsons yellow shocks are terrible, but no suprise there. And at this point they are so thoroughly cooked they do almost nothing. The Timbren bumps do a good job, I need to shorten the extensions to maximize travel but waiting for the next set of tires.
Once the swap is running well I'm planning on a suspension overhaul. Current thought process is to stick with the VT in the rear, go VT in the front. Might be a little stiffer than perfect but should support the load better. Then leaning towards ADS 2.5 three tube bypass shocks on all four corners, valved correctly for my setup.
In the same vein, debating between 37s and 38s. Probably will come down to $.
Who makes the slinky coils?Probably pretty close to what my plan is right now. Thinking I’ll swap to eye mounts for the shocks so going to bypasses is simpler.
Ideal world, Slinky coils, 2.5 bypasses, hydro bumps. Since Slinky seems pretty much NLA in the US, probably VT front and rear. Unless there’s another coil that’s closer to the Slinky that I’m unaware of.
End goal being a truck that rides extremely well while loaded for camping on whoops and chopped up crappy fire roads but can still flex reasonably well. Not looking for extreme crawly boi flex from this truck, but better than what I have right now.
Autocraft made them, I don't believe anyone makes them anymore.Who makes the slinky coils?
Used the Torfab mounts and adapter! Also used their shift linkage with some minor tweaks. Solid stuff overall. I have a couple minor fitment issues (passenger head extremely close to the firewall, AC compressor hits motor mount) that I believe are related to my truck specifically, not to the kit itself.Great build! I didn't see it listed but what swap kit and t-case adapter did you use?
