Pakistani top install
Richmond, VA
Yes, I'm finally getting around to this on my '82 40 after 2 years! Just reopened the box and I seem to be missing the front windshield channel. I have an email from Eshan stating that this would be part of the package. Did anybody else from that initial order not get one? What have others done to create one?
Also, after a year or so of experience does anyone have nay advice on things to do/not do? Any tricks to share?
Did you like the fasteners in the stock locations? Did you use the STC twist lock fasteners or another source? How tight did you pull the top to the fasteners? I will have to drill new holes in to the Gozzard tub with no access to the back side. I am thinking Nutserts for the fasteners. Thoughts?
I've got the archived info, just hoping that there is some new wisdom about these tops
Thanks, FJinVA
TLCA #6266, CLCC, BBRC
'82 FJ40, '99 UZJ100
Did you ever get your STC fasteners? I'm done with everthing except that...marine shops have twist lock fasteners with a single sheet metal screw and also have a version with two holes (for two bolts). I'd really like to get a fastener with a single bolt sticking out the back!
I cobbled together a windshield channel...but I'd recommend getting one from SOR. It's worth the $80.
Tim
my top came with the windshield channel, you should contact Eshan, he has another shipment coming soon, maybe he can send you one. the fasteners he sent are made of such thin metal they bend very easy, i haven't installed them and don't want to. i did have to cut an inch or so off of the bottom of the rear corner vertical tubes in order to get the top to reach the tub. Eshan suggested putting a slippery plastic sheet ( i used a garbage sack) over the rear horizontal tube to pull the soft top tight and then remove the sack. that worked for me. where can we get more of the tie down brackets?
I used the OEM channel and found it to be a bit tight and it needed to be split open a touch. I am not sure about the fasteners he sent. I used OEM tub fasteners and found some good SS parts for the fabric side.
The biggest issue I had was getting the fabric tight around the door bows. It wanted to buckle up right where the top bar meets the verticle bar. I pulled it tight and let it sit in the sun for a day or so. Eventually got it tight enough.
I wouldn't want to drill that many holes into the side of my '77...I'll stick with my SOR Bikini top and my hard top...
Thats nice for you wsdavies :D
I had trouble with the channel he sent on my '71 since the windshield wipers are on the top of the frame, and interfered with the top. I think he made the tops to fit post 74 years (whenever they went to ambi doors and wipers at the bottom of the windshield).
Anyway, for the windshield, since the wipers wouldnt allow me to get the top close enough to the frame for a tight fit without the wipers rubbing on the top, I got some 1/8" or so flat stock and drilled slots in it so I could push it forward or back and tighten up the gap on the channel.
On the back, since I have the half dooors, and the top was made for ambi doors, top door hinge interfered with the most inner strap. So I am not using that strap. It works fine though. Maybe Ehasan has addressed these problems by now though, since I've had my top for about 4 years now.
For the snaps, I am using these button style ones that they use on sail boat riggings, and they work great. The post has one stud that fits nicely into the stock holes, and the part that mounts on the top has a wide surface so its not likely to rip. Heres some kinda bad pics of my top with the buttons, but you get the idea..
http://www.finespline.com/cruiser/
-Dustin
I was in the original 10 orders. There was a real mix up when the kits went through customs in Thailand. Apparently they inspected mine and another kit together, and then did not return the parts to the appropriate boxes. So David in Indianapolis and I had to divide up our kits and ship half of each to each other. The shipping company took care of everything, so it was no big deal, just a bit of inconvience. I also got an extra windshield channel that I mailed on to Lance in Texas.
Remember, after sliding the top through the channels, tap the channel closed again, so the top does not pull out while on the road.
I used Red Dot turn buttons I got at the local Ace hardware. They have two mounting screw holes each, I used pop rivits to install them. Two years later they are still like new. The rings for the straps have all rusted, and some pull tabs have broken off the zippers, but other then that, every thing is still doing fine.
I had a little trouble with the fit of mine because of my cage, the over head hoops arc up a little too high. So I'm without the front bow hoop, just the radiused ends. I took a length of small rod to span between to keep the top from sinking between. When it rained and snowed, we get very little snow here, but when it does it is very wet and very heavy. The top would collect in the front and stretch down into the truck. I added another small rod between the front bow and the front hoop of the roll cage. A picture is a lot easier then trying to explain this, so two are attached. On the fit of the top, the bow system has slots for the bolts that hold it together. These slots can be used to make the top of the frame larger or smaller, which can take up or give you a little more than 1/2" of tension in the top.
gary
I think you were in the original 16 :D
He sent Daniel one for the initial test fit, then Daniel, Mark myself and two others got our 5, then your box load was shipped. We were going to get in on that shipment container but were worried that the potential strike by the port workers and the iraq war were going to delay the tops shippment a long time- if not infinitely. So we ended up shipping through DHL or someone like that. Got our tops in about a week. :D It was fun watching the package travel through the middle east then to the states.
-Dustin
He sent Daniel one for the initial test fit, then Daniel, Mark myself and two others got our 5, then your box load was shipped. We were going to get in on that shipment container but ...-Dustin
Could be I guess, mine was not in any container or group buy, it came to my door by DHL. I know it was before the first group buy put together on the LCML.
Eshan said he sent two individual orders out at the same time, so they hit customs together. I had been in communications with Eshan quite a bit before all that because he was on the OBH list when he started his Islamabad Jeep Club, it was a year or so later that he showed up on the LCML. I ordered mine quite awhile before he started delivering. And he told me I got a discount for being in the first ten anyway, thats all that mattered to me :) .
gary
Pin Head: Good info! Here's a link: http://www.vicarinternational.com/fasteners03.html
EDIT: I called these guys ... http://www.interior-supply.com/turnbucklefasteners.shtml ... who carry those same pieces at $1.95 each. He couldn't tell me the size, but the "barrel stud" is basically a nut on the back accepting a machine-thread bolt. He couldn't tell me the size. I'll report back after I get some!
Dustin: Looks like the straps have been moved, my straps (from a top made in 2004) do not interfere with the hinges on my swing out doors. Green Lantern posted a link to my pics above (thanks Nick!).
Tim
