PAIR system delete, Utah emissions?
Orem, UT
I dream of turning my '94 into a camping rig, for which I'll want the biggest RV battery i can fit as a second battery.
So at a minimum I will have to delete the PAIR valve silencer. But why not delete the whole PAIR system and stick my o2 sensors (Recently replaced) right into the manifold?
I'm confident that a Utah emissions inspector won't notice that the PAIR system is missing, and if they ask about the plug where the PAIR system used to connect to the air filter i'll just say it was an intake silencer that was in the way of my 2nd battery install.
I understand that PAIR is only active for certain parts of acceleration or deceleration. In my county, there are no 4wd rollers and they just stick a sensor in the tail pipe and rev to 2krpm for a set length of time. In Utah your vehicle is only required to pass the emissions regulations for model year it was built.
Do you think i can get away with it? Maybe with a couple quarts of isopropyl in the tank.
Plus this way i could add a burrito box to the exhaust manifold.
@Timpanogos Slim have you had any trouble with emissions since doing this? Been tearing my motor apart and ready to get rid of all the EGR/PAIR crap but dont want to have it bite me in the butt when I go to get it tested....
ps. I am down in Springville
From a legal standpoint, you cannot remove any federally mandated piece of emissions equipment. That having been said, I'm not certain if the PAIR system is a federally mandated component the way catalytic converters are. Try it and see... with UT doing away with Safety after January 1st, the shops may be looking harder for things to fail/up sell you on. It depends on the shop, too... I passed this year without mudflaps, with spring spacers, and rolling on retreads.
As an aside... a few other local 80 guys and I are heading out to Delle to do some quasi-overlanding and exploring on December 2nd if you guys want to join in. We're meeting at 9 at the Tesoro off exit 70 on I80. If you've never been, it's everything from groomed dirt roads to impossible climbs, and every obstacle is optional so a stock unlocked rig is just as capable of going there as a tube frame buggy. Bring a days worth of water and food, though. Shoot me a PM if you plan on coming so we know to be on the lookout for ya.
I don't know if you can get an inspection in Salt Lake County and it will be valid in Utah County, but there is a guy who has an inspection station on 3141 S Main St in Salt Lake called quick IM state inspection who will pass it. He doesn't even have a dyno tester which I thought was required years ago (not that you can do it on an 80 being full time 4wd). There's no plate brake tester, he uses a flashlight to look at the pads. He passed mine with a broken taillight, a leaking exhaust and a headlight out.
I bet he won't be in business much longer.
Been going there for 5 years now, he has a certification from the Salt Lake County health department on his wall that's current every year.
Maybe, but he probably didn't have his customers posting his questionable illegal practices along with his business name and address on the Interwebs.
Actually none of his practices are illegal or questionable. Technicians can advise or fail on safety inspections in Utah, most will fail you because they also run a repair shop there as well and offer to fix it for you. He only does inspections so he will advise and it's up to you to remedy the issue. Not to mention safety inspections go away next year. The OP asked about an emissions device which to my knowledge isn't required here, so the only way he would fail is by a visual inspection or if disabling the device caused the vehicle to fail. But the shop who has a vested interest in failing him will if they can to try to get his business.
I'm so glad i live in Texas in ector county. They do t check emissions. They don't pop the hood, and the don't look for cats. It's pretty nice.
Oh, I thought you mentioned that he passed you with a broken taillight and inop headlight, both of which should be reject items. I stand corrected.
Fu$%&
Question is do I bother with trying to keep all the old components in the car but use plates and plugs to render them inoperable, or do I just rip it all out and hope they dont look..... hmmm :hmm:
I saw nothing about fines though. Basically says if those parts aren't there, you fail the test and must put them back to re-test.
I never did it. I just wouldn't be surprised if the average tech doesn't bother to notice.
Removed my PAIR system, relocated my 02 sensors, and disabled my EGR system though the components are still in place for visual appearances. (EGR blockoff plate at the head, and internally plugged vacuum hoses.) Truck still passes emissions with flying colors! Waiting to yank the cats off and rid the truck of the floorpan heater...
