Painting hood
PHX AZ
Well, my hood has pretty bad rock pitting. I can see a few spots are starting to rust due to the chips being all the way down to the metal. My plan is to detach the hood and sand blast it, thus removing the old paint and the rust. Then I will give it three coats of paint, with wet sanding in between each coat, and finally, 3-5 coats of clear.
Have any of you sand blasted on your trucks?
Has anyone had trouble matching paint colors for trucks? What would be a good brand of paint?
How necessary is it to do the blending work that I read about?
Thanks for any info.
Justin
The paint and body forum would probably be more approptiate.
Sand blasting is unnecessarily harsh and costly unless you already have the equipment. Just sand it down to bare metal with a random orbit sander. Prime with a self etching primer. Prime with a high fill primer and wet sand with 400 grit silicon carbide paper. Shoot 2-3 top coats of OEM color (about $80 per quart on line) and then spray with 3 coats of clear coat. It is not that tough of a job. I have been satisfied with the color match from several on line vendors of touch up paint.
Eh probably right about the paint and body forum maybe a mod can move this thread for me. Thanks for replying about the how I should go about this project. I do have a question though. Would an orbital sander get rid of the rust? Also you wouldn't happen to know the vendors websites would you?
Thanks
If there is visible rust in the rock chips it would be wise to take those areas down to bare steel.
It is not necessary to sand down the whole hood to accomplish this, especially if theres only a handful of chips.
What I usually do is:
-Outline all of the chips/rust spots with a paint marker or a sharpie. Make sure you dont miss any cause they will come back to haunt you.
-Remove the paint/rust. When doing tiny little spots such as rock chips I have used a dremel with success. The smaller the patch of bare steel the easier it will be to fill.
You will now have low spots in the paint where the chips/rust have been removed. A thin coat of bondo and some sanding will bring the level back up.
Now you can scuff up the rest of the hood and paint away.
As far as paint goes, find the paint code for your shade of 80 then get it mixed at the local auto body place. I usually get spray bombs since I dont have a sprayer. You will also want clear coat. My advice is to get the cc with hardener, this will make the paint job a lot more durable.
This pic is factory matched paint w/o cc
This is a recent job I did on my lift gate using the same paint but adding 3 coats of cc w hardener. Turned out nice and glossy compared to the flat look the hood has.
Hope this helps, and remember youll see all of the imperfections after the first coat of paint so dont skimp on the prep work.
D
If you want to take it down to bare metal, thus removing the original direct to metal primer, soda blasting is the WAY TO GO INSTEAD OF SAND BLAST. Sand will pit and potentially warp the metal especially noticeable on a large flat surface like the hood. Or just sand paper on orbital DA with 220 for the pits, feather out all around, then sadn overall with 320 and then follow up with 400. Use the green etching primer from rattle can for the bare metal areas, primer surfacer whole hood, bolck wet with 400 then 600 before sealer primer. Then color base three coats and clear 4 coats, Final wet sand clear after 24 hours 2000 grit and then machine buff with compound (cut and buff) and then polich in three steps to final glaze. Its alot of work and many steps but depending on how particular you want to be, the final result will be worth the extra time and work. The color probably will not be exact match just because of the many variables but because the hood is horizontal and fenders vertical for the most part, light will hit from different angles and may not be as noticeable. Metalics are harder to match mostly because of spray gun tip and technique, temp/humidity, speed match to reducer to temp ect. Slower reducer allows metal flakes to lay flatter thus reflecting more light and making paint appear lighter. Faster reducer suspends flakes better thus giving that sparkling metallic loook and deeper color appearance but to fast can create pin holes in film surface.Pin holing is more likely to occur it the clear coat as the base coat does not go on as wet. I use a different gun for base metallic (C.A.T. Technologies) and a SATA Jet for clears. Where you have your paint mixed and get supplies, they should be able to help you get the job done right.
