Paint
I'm am looking for a semi-gloss or satin finish auto body paint (enamel).
I've searched here and elsewhere without much luck. Trying to hide a, not so great sanding job. Anyone know of such a product.
Thanks
Just paint with gloss enamel and then scuff the finish after it's hardened.
you can use the cheap synthetic enamel and let it fade on it's own (which happens rapidly here in arizona) or you can add a product called "Flattner" which any auto paint supply should Know about.
Zero Rust dries flat.
Thanks
PPG (and I'm sure all other auto paint mfgs.) make a flattner additive that you can add to any of there paints. Dulls it down to about semi or satin finish. Fairly common, I know our local auto paint store carries it on the shelf. If your local auto paint store doesn't have it, I'm sure they can have it the next day.
With that additive you can pick any color you want.
Matt
Maybe color tint your primer and call it a day for that low gloss, low luster, maximum hiding of that not so great body work. However, I agree with dgangle above.
In general you want the durability that comes with a hard, glossy paint. If you wet
sand with 2000 grit sandpaper (careful with edges and corners) and then hand buff
you will knock quite a bit of the gloss off and still have the durability of a hard
paint. We do the same thing when we refinish furniture.
Get PPG's primer/sealer K36 with DX61 hardener, add appropriate color since this is a tintable primer. Use the darkest shade of the color you want as the color additive. It will not be the color you will want, BUT, you can, at a later date, sand it properly and shoot a single stage color over it.... or just get the color in single stage that you want and hold the spray gun about 3 feet away and shoot it DRY... it will be like sandpaper. just some thoughts. BUCK mentioned the PPG flattener, DX685, this works great and you can change it from a semi-gloss to egg shell. Good Luck.!!
I thought about just using a first stage paint that is supposed to be clear coated, but have been warned that certain chemicals (de-greasers etc...) will turn that paint white or very cloudy. I am going to use the flattener. Hopefully you'll see it soon on ROTW. Thanks all
The flattener linked to is for use in 2K eurathane paints - the two stage basecoat/clearcoat systems that are predominently used now. You said that you wanted an enamel. Though there are eurathane enamels (ppg's AU products) I'd check carefully to find out what effect using that product in one of the enamels might have.
Auto painting is all about chosing a system of combatible products. Taking one product to use 'out of context' might bring a hard to remove mess.
BTW, I was serious about scuffing enamel. I'm repainting some enamel right now and have to break the gloss of the original paint to help the new paint adhere - to give it something to 'bite'. The red scuff pads that auto paint stores sell are a fine grit thing and I almost stopped right there after scuffing down a fender because I thought it looked pretty nice.
