Paint question, cost of...
Mad Chemist said:
'm looking at a single stage paint, with no plans to clearcoat.
This is by no means a restoration, and is meant to be functional. A durable paint that will look nice, yet still hide all the Northwest pinstriping it'll hopefully get, is what I'm looking for.
Keep in mind another option that I'm using is vinyl paint. This is used factory on all kinds of soft materials like jeep flares and rubber front bumpers on minivans and painted plastic parts on the side.
My friend owns a body shop and reccomended it to me.
It is REAL easy to get a semigloss finish (the other stuff is real hard to match if you paint again later)
It's tough! (I rubbed the bark off a tree on my fender, bent the fender a bit and the paint isn't even pinstriped!)
It is real easy to spray
Best off, in a semi flat it covers all kinds of bodywork problems!
oh yea... and it's like 1/4 to 1/2 the price of evrything else :D
Scott shoot straight enamel ??? you gotta be kidding, may as well pay a visit to Earl. Supplied air respirator...maybe a little overkill. A good MSA properly fitted full or half face respirator with an organic cartridge (GMC-H...IIRC) will be more than adequate. Keep the area ventilated after your out of tack, unless you really like wet sanding and buffing the dirt out. Prices I shelled out for materials last week alone, all are PPG line:
1 gallon Omni hi build primer...............41.25
1 QT harderner MP282 for above..........18.80
1 gallon reducer DT870........................34.20
1 QT DCX61 Harderner.......................70.60
1 QT DCC Acrylic Urethane (blue)........57.45
1 QT DCC Acrylic Urethane (ivory).......57.45
1 QT DP90LF Epoxy primer...................36.20
1 PT DP402 Hardener..........................20.75
Oh my that is indeed expensive shiite. I need to consult with my buddy who owns a shop to see if I am paying full retail. I know prices for this stuff keeps climbing but this is getting pretty stout.
Actually, if you are considering spraying a paint that contains isocyanates, and you like living, it might be a good idea to spend some time researching this. Isocyanates are one of the nasty ingrediants that make modern paint good. But, as in everything, there are a few catches, including:
1. chemical pneumonia. This can occur upon exposure. Lungs fill with fluid, and you're dead.
2. liver failure. spray your car one day, die the next.
3. liver cancer. spray your car, die ten years later.
One of the first paints to use the isocyanates in the 70's also initially recomended charcol respirators. Then they had the sticky situation that people using the paint in the recomended way started to occaisoinally die off. Eventually, it was determined that suplied air respirators were required.
Now, the question is whether the risk of inadvertant, self imposed, death is worth the benefit. For me it was worth a few hundred dollars to buy a supplied air respirator (which was paid for in savings in the first use). But everyone must make their own decision.
All just my opinions, but check it out.
From what he was describing he was looking for the "Earl" finish. I was not kidding at all, I have seen enamel jobs done with skill and care that looked better than a expensive poorly appled urethane job. Each has it pluses and minuses, cost over quality of course.
Steve,
I may be incorrect, but I do not believe any of the PPG products I listed above contain isocyanates. If I am correct with that then and properly fitted full or half face respirator would be acceptable. Risk is everyones personal choice. Risk, exposure factors, and uncertainty factors all make up the magic acceptable exposure levels that we can "safely" be exposed to. One such factor that is used, is they base the acceptable exposure levels based on a person working with the chemical dujour for 8 hours a day, 5 days a week, for 20 or so years. Hopefully, it won't take anyone that long to squirt their cruiser. If it does, then are bigger concerns than isocyanates. I agree you should know what your working with and protect accordingly, and you also need to educate yourself of what was used to develop the "safe" exposure level. IDLH chemicals...well thats a different story.
Scott,
99% of the quality comes in the prep work. For me, I wouldn't spent all the time and effort to get it prepped right just to put straight enamel on it. If your gonna do an Earl job just take it to Earl, I don't think you or I can do it for cheaper....oh ok maybe by brush or roller. Straight enamel just won't hold up...I think they start fading before they are dry. Enamel is cheap for a reason.
toddslater said:
Steve,
Scott,
Very true, it's all in the prep. I think there is a van in parking lot at work that was painted with interior home latex and a roller, it has little pink flowers painted all over it.
Mad..although not the most thorough primer on paint types..this link may help to answer alot of your questions...or cause you to ask more, both are good
http://members.tripod.com/~bobstory/faq.html
At the end of the day, paint quality and durability like many things (at least not the things bombarded on us daily from Madision Ave...) is a function of the price.
