Painlees Wiring Harness Help Needed
Meriden, CT
Hi,
I'm hoping that some of you wiring experts can help me.
I'm going to rewire my 74' FJ using the "painless harness" and have a couple of questions about the rewire that I hope someone can answer for me.
The first question that I have is about the hazard switch wiring.
The new harness has two relays, one each for the turn and hazard that have power out.
The original harness also has two power wires in to the hazard switch, one for the turn and one for the hazard.
The original harness has one wire for power out to the flasher relay. From the relay there is one power wire out that is split with one wire going to the turn signal switch and one goig back into the hazard switch.
I thought that for the new wiring I would use the two power in (turn and hazard) to the hazard switch and have one power wire out of the hazard switch (the one that would have gone the the flasher relay). I would then split this wire with one going into the turn signal switch and the other going back into the hazard switch.
Is this the correct way to wire the hazard switch?
The second question is about the wiper switch/ motor wiring.
I was thinking that I would leave the existing wiring for the wiper motor / wiper switch as is. with the exception of connecting the new harness power out to the existing power in for the wiper motor.
Is this the right thing to do?
Is it a GM harness? If so you will need GM turn and hazard switches and lights for the GM harness to be completely compatible.
If you want to run the Toy turn signal switch and flasher switch, then they use two separate fused power feeds. The turns use "key" on power and the hazard feed is always hot. Later (73? and up) Toyota circuits use a single flasher for both hazards and turns.
The wiper circuit is pretty simple, so just changing the power feed to the switch should be no problem.
Yes, it is a GM style harness.
I would like to keep the original switches.
i was able to use the stock headlight and the turn signal switches. i will see if i can get the diagrams i made out of storage. really all you need is the factory wiring diagram and you should be able to figure it out. the hazard switcha dn turn signal is the biggest pain in the ass. the wiper motor was not as bad but i ended up gettin an on off on switch from the parts store and using that. i will get back with you.
I didn't have too much trouble with the headlights. But I gave up on the hazard light switch and just put in a toggle. The factory diagrams helped, but I found just taking the switches apart enought to see the contacts helped me put it all together. I used the wiper switch and that wasn't bad. I think there are 4 wires (low, low ground, high and high ground).
I'll see if I can find my install notes as well. Keep at it, it does take a lot of time and can be pretty frustrating.
awp
I ran the Painless kit on my project using the factory Toyota column and all of the factory switches. Mine worked out well after a bit of troubleshooting regarding the hazard/turnsignal circuit(NO THANKS TO THE TECH LINE AT PAINLESS!!!); G/R-switched 12V positive from painless harness
G/W-constant 12V positive from painless harness
G/Y-output off of switch to T/S harness in column(Right signals)
G/B-output off of switch to T/S harness in column(Left signals)
G/O-connect to battery side of flasher
G/L-connect to load side of flasher
Disconnect the flashers from the Painless kit as they are not required.The flasher that you wired into the hazard switch will take care of both turn signals and flasher circuits.
