P0403 - not a blinking MIL
SC
My truck had been running a bit jittery and sluggish, and I got it back from getting the A/C fixed (new compressor, evaporator), and then it threw this code (misfire on cylinder #4).
I checked the plug in cylinder 4, and it is firing fine. The next step in the FSM had me check the ECU, and that was fine. The next step is to remove the throttle body, and check the injector resistance, but honestly I will not have the free time to get to that for at least two weeks. My question is this - if the closest Toyota dealer is about 30 miles away, do you guys think that I will safe driving it up there, or can I potentially damage the engine?
I was thinking that I read somewhere that a solid MIL was to be investigated, but a flashing MIL meant pull over and call the tow truck. Is that correct?
As always, thanks for your input.
What is the resistance on the plug wires? When was the wires and dist cap last changed? I had the same about 4 years ago and it turned out to be the cap.
...oh yeah, it seemed to be brought out by the rain and wet roads.
swap the #4 plug with the #1 plug and see if the misfire moves? And I wouldn't drive it on only 5 cylinders
The #4 plug is firing outside of the cylinder - also the guys who were fixing the ac changed the plugs when it threw the code on them.
The cap and wire were changed probably 2 years (maybe 10,000 miles ago). I forgot the exact resistance reading on the wires, but it was well within spec according to the fsm.
Sounds like false memory. To the best of my knowledge, the CEL light is either on or it's not. Never flashing under normal driving operation.
Curtis
Curtis
Here's what the FSM says...
"Misfire: The ECM uses the crankshaft position sensor and camshaft position sensor to monitor changes in the crankshaft rotation for each cylinder.
The ECM counts the number of times the engine speed change rate indicates that misfire has occurred. When the misfire rate equals or exceeds the the count indicating that the engine condition has deteriorated, the MIL lights up.
If the misfire rate is high enough and the driving conditions will cause catalyst overheating, the MIL blinks when misfiring occurs."
The engine only has 135,000 miles on it, so I really cannot believe that it would have had some sort of catastrophic wear and tear on it already. I've been pretty good with oil and filter changes on it.
Oh yeah - it's not in my sig any more. :doh:
1996
OK, then this might apply
Recently I've had a rash of MAF connector issues. There was one on here a few weeks ago and there have been several through my PM box.
What seems to be happening is the pins inside the connector are becoming fatigued and giving bad info to the ECU. It's not enough to throw a MAF code but I've had two instances where it gave miss fire codes.
Now you might not have my MAf but that really isn't the issue. It's more about disturbing the connector and having things sit in slightly a different spot. The AC techs might have removed of bumped the connector during servicing which started the problem.
I would suggest removing each wire one at a time and bending the leaf spring inside so it makes a better contact. I do this by sliding a small screw driver in from the back so it's under that leaf and then rotating it to make it a tighter fit.
It might not be your problem but it's a no cost fix if it does work.
Stupid me, but MAF = mass air flow sensor, right? That's the electrical connection on the accordion tube coming off of the air filter to the throttle body?
Sorry, yes that is the connection. When you remove the plug you'll see a white strip of plastic inside. That is a locking device and you need to pry that up and out of the connector. Then looking inside from which it came you will see a small latch on each connector. That latch needs to be lifted up so the connector will slide out.
Now once the connector is out, look into the end on the opposite side of the wire and the leaf spring is viewable. That springs needs to be bent so the gap between that spring and the opposing side of the connector is as small as possible. That way you will get a good contact with the pin that is on the sensor.
I can send you the MAF install guide which has pictures of how to take apart the connector.
Well, I bent the connection to ensure a better hookup, but I don't think that's the problem. :frown: After I tried that, I revveed up the engine to about 2500 rpms or so, and the MIL began to flash the P0304 code.
I removed the spark plug from the 4th cylinder again, and the engine runs exactly the same. I know that cylinder is getting spark, so it has to be a fuel or a compression issue. I'm thinking that instead of taking to the Toyota dealer for a full diagnostic check, I'll run it over to a shadetree mechanic for a compression test. If that checks out, I'll take it to the dealership, or at least to the good local mechanic. If the compression sucks, I guess I'll know the answer.
Can you hear the injectors ticking? On my truck I can hear the injectors fire and I'd imagine a clogged injector would sound slightly different while firing.
If there is no difference from pulling the plug (IE cyl 4 is never firing) I'd feel pretty damn confident it was an injector issue. Even with lowish compression and weak spark it'd still fire some.
Will, go buy a compression gauge at the parts store. You can probably get a decent one for $20, which will be less than what a mechanic charges you, unless you have a hookup.
You could also probably check if it is getting fuel by cranking the engine over with that spark plug out and compare what comes out of the hole with one of the other cylinders that is working properly.
I was thinking compression gauges were more expensive than that.
Oh well, compression gauge has been purchased - hoping for the best tomorrow.
