P0401 code at highway speeds only
Riverside,Ca
I am trying to figure out my trouble code. P0401 only. Did vacuum test using mityvac and i either didn't do it right or its inconclusive. Anyway, i can drive around town for hundreds of miles without that code coming back but as soon as i get on the highway and bring it up to speed, boom, code comes back. Any ideas on where i should start replacing parts?
Speaking of that, should I have a different colored modulator? I have the green topped one.
So I take it this is where I should start?
ooo, i've got that same pinhole, i was gonna start off with an EGR valve but i guess i'll start off with the modulator...
i just figured it was supposed to be there
There was some buzz about the green top ones before I joined. I could be way off but I inferred that they were inferior to blue. FWIW my failed one was green and the replacement blue.
If there's a stain on yours then it only takes a minute to pop the modulator off and you've got a mitivac for a quick test too.
I've tested the modulator from the bottom port and it holds suction. But it is really dark which leads me to believe I'm gonna start there first anyway because it is obviously shot and a simple fix. Shot beno a pm already. We'll see what he has to say.
For $55 I think I'm just gonna get the oem option. I know that's just one in a list of crap that could be wrong but from there if I still get the code I'm gonna go after the vsv and if that doesn't work in gonna light it on fire in my driveway.
yea, i just got the number from cdan myself, gonna have him send me one on tuesday....
i already blew the filter out with the air compressor and noticed that pinhole, was going to start testing the valve per the FSM, but i'll just swap modulators first...
this is after i've already replaced the VSV which tested no continuity a while back.... so... just gotta go through one at a time i guess
While you're waiting on parts if you want to remove the temp sensor you can do two things.
One is use some 0000 steel wool and clean the sensor and then put it on an ohm meter and wave a cigarette lighter under it as if you were using shrink tube. Notice the resistance change as it heats up? then it's probably ok.
Two is using a bottle brush and some intake/carb cleaner spray you can clean some by poking the brush into the sensor's hole and it will make it all the way across to the EGR valve spray and brush a bit there and see if cleaning that out helps.
Went with blue top modulator from beno. Problem solved for a little bit but it's back so I suppose I will move on and replace the vsv. That will be my next step. Plenum was just off and mechanic said it looked clean so should I just replace it from the bottom and not worry about taking the top half off again?
How does the EGR temp sensor look? I had this code a few years back and it was because the EGR temp sensor was caked with a thick layer of carbon. I used a brass ire brush and cleaned it and that took care of the code. I clean it every few years now.
It's quick, cheap, and easy.
Just my experience. Your results may vary.
I will pull the temp sensor when I get home right now. It's at the muffler shop as we speak. Whoever had this truck before thought a two chamber short flowmaster was the way to go. SO loud.
An Ultraguage gives you the readout from the intake temp sensor so i would guess that getting a good reading via the Ultraguage rules out the temp sensor causing the P0401? My intake has never been off and I need to do the VC gasket so I am attacking it all at once. New VC gasket, plugs, plug tube seals, clean throttle body, upper intake passageways, new modulator,VSV for egr and all new vacuum hoses.
So this is what my temp sensor looks like. Gonna clean it up and test it. See if that works. Then, give up and do the vsv.
The EGR temp sensor is different than the intake air temp sensor.
